southcoastcruiser Padawan
Joined: 04 Jun 2011 Posts: 71 Location: South of France
Posted: Wed Jun 08, 2011 9:52 pm Post subject: '71 DAILY WORKER with EJ25 SUB |
I'm Thierry from France, I'm working since 2 years with my 71 bay, 45000 kms ....
I'll begin the sub conversion in 2 weeks
I have upgraded the chassis before
4 konis
big anti roll bar front and rear
full 944 turbo brake front and rear
hydraulic hand brake
Hurst line lock
BBS lemans style wheels 7,5 x 17
tyres 205/50/17 Continental sportcontact3
some pics
the conversion
EJ25 1998
sump Bugat5speed
oil control baffle Cosworth
Plate adapter DS tuning
Body throttle reverser fron RJES
speed sensor RJES
Bosch fuel pump RJES
fuel filter RJES
Wiring harness modify by RJES
Rabbit GTI water tank x 2
Rabbit GTI fan x 2
reversed CSP Python exhaust
VDO gauges
Porsche 915 gearbox magnesium case 7 x 31
Wevo black shifter
the sump from Bugat5speed for the Subaru engine....
plate adapter for Subaru engine and Porsche 915 gearbox....DS tuning
throttle body reverser
throttle cable
fuel filter
Bosh fuel pump OEM
speed sensor
oil and water sensor
T25 expansion bottle
water gauge
oil pressure gauge ( another one cause the mine is just for 5 bars pressure)
rabbit GTI fan
rabbit GTI water tank x2 :mrgreen:
to mount the oil sensor...
AN Fittings, Stainless Steel and nylon Braided Hoses
915
Wevo shifter
working is good for him !!!
Thierry |
doppelganger Jedi Guardian
Posted: Wed Jun 08, 2011 10:46 pm Post subject: |
some nice bits you have there ,looking forward to the build pics
really should post pics of my new engine fit sometime  _________________ vwdrc class rep
Posted: Thu Jun 09, 2011 5:06 am Post subject: |
thanks
you want to see pics about the restoration of the bus ?
for the moment , the engine is 1600 2 x 34ICT ; I'm collecting all the parts to make the conversion
When I bought it
the first version
944 rear brake
Subaru EJ25
testing before removed from the Legacy
http://www.youtube.com/watch?v=2xl7MBe9RPw
sven Jedi Guardian
Posted: Thu Jun 09, 2011 8:29 am Post subject: |
Wow! You REALLY made my day!  |
Posted: Thu Jun 09, 2011 11:33 am Post subject: |
Sweet looking forward to this one..
'71 Bays with 944 brakes rule
How did you make the brakes fit ? _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
Posted: Thu Jun 09, 2011 5:17 pm Post subject: |
hi
the front is welded plate make by one of my friend
the rear is the oldspeed kit, not really good with the handrake so I ve placed an hydro one.
for the rear atmo/turbo same size of drills
for the front , you can buy plate from t2d and a pair of early splindles
for the hydro some pics
Line lock
Alex (FTS) Jedi Guardian
Posted: Fri Jun 10, 2011 10:40 am Post subject: |
Tanks
There s a "small" problem with m'y gearbox ...it s dead so Icould must report the swap.
For the moment I m on the sump, cut the oil sucker,sels and modify the Cosworth baffle
Pics tonight  |
Posted: Fri Jun 10, 2011 6:55 pm Post subject: |
so I must cut a little bit the baffle
the sucker too
Posted: Sat Jun 11, 2011 3:16 pm Post subject: |
the cut sucker
The problem with my gearbox is closed, I 've bougth another one, aluminium case ( more stronger) more longer (8 x 31)
the max speed at 6000 rpm with 205/50/17 is 140 mph
great for me , not for the police
just for fun
in France when you put a sub engine into an lawn mower VW , everyone thrown you of the stones ( I don't know if it's the good words)
so , I prepare a secret project.....And I found that one of my friend thought about that in secret too cause I love them....
( this pics is one of my friend , who's put an EJ 20 + all the trans into a superbeetle )
JESUS !!!!!!
Posted: Mon Jun 13, 2011 6:06 am Post subject: |
sunday work
put in place the baffle, the sucker and the first part of the sump, the screws are too short ! I must waiting to finish
TO FIT THE BUGAT5SPEED SUMP YOU MUST REMOVE THE ENGINE MOUNT
the oil sensor adapter
the plate adapter and the flywheel
new spark plugs and ignition leads set
and repainting and washing some parts
Last edited by southcoastcruiser on Mon Jun 13, 2011 9:12 pm; edited 1 time in total |
Posted: Mon Jun 13, 2011 6:00 pm Post subject: |
HI
the project continue..I've found another gear box more longer, I 'll receved it at the end of this week  |
