Is one fan enough?
RatCamper
PostPosted: Sun May 15, 2011 4:23 am    Post subject: Is one fan enough? Reply with quote
G'day. I have a bit of a problem. Currently I have one 10" (I think) Davies Craig thermo fan fitted above my angled frame rail rad with scoop in my '75 bay. The radiator is a 3 layer one from a JE Camira (once again, i think). The trouble I'm having is the clutch cable is severely fouling where I would like to put a second fan. The mounts are already there and all. I don't want to shift the clutch cable tube.
What I want to know is do you all think that one fan would be adequate? I know that when it is sitting there idling the fan keeps the temperature where it should be and does turn off. My worry is while driving. I think the scoop should be enough, but what about low speed driving and hills?
edit:
I forgot the important bit. The motor is a Subie EA81 with a Holley progressive.
Joel
PostPosted: Mon May 16, 2011 9:06 pm    Post subject: Re: Is one fan enough? Reply with quote
Better call it a Mk2 Vauxhall Cavalier or Opel Ascona C Radiator so our European friends on here know what it is Laugh Out Loud
RatCamper
PostPosted: Tue May 17, 2011 2:09 am    Post subject: Re: Is one fan enough? Reply with quote
So it is a cavalier. I couldn't find anything that really said either way.
Joel
PostPosted: Tue May 17, 2011 11:32 am    Post subject: Reply with quote
Well the running gear anyway.
Bodies were made here which was why they fell apart on the trip home from the show room.
PostPosted: Tue May 17, 2011 7:03 pm    Post subject: Reply with quote
if the rad is big enough and scoop is efficent enough at the fan should only opperate when in traffic and under high load ie climbing a hill at motorway speed fully loaded. ps are you sure the fan you have is 10" that sounds small? thought a cavalier one would be about 14" that should be plenty
RatCamper
PostPosted: Tue May 17, 2011 9:35 pm    Post subject: Reply with quote
Pretty sure, yes. This radiator came from an earlier bus that someone converted and it was set up to run a couple of fans side by side. Only in my case one doesn't fit because f the tubes. I had to do a lot of work to get that rad to fit at all to be honest.
Not sure if I'd call this a good thing but its PO was running the rad with one fan seized solid and the other freewheeling on its shaft.
PostPosted: Sat May 21, 2011 12:09 am    Post subject: Reply with quote
I've hesitated on a comment...but I'm only running 1 fan.
It;s from a Ford & it's meant to be a blower from an a/c rad. Don't ask what Ford - approx 16" diameter.
It only comes on in stationary traffic (M25) but my scoop is huge. Fan kicks in for about 90-120 seconds
It might be worth PMimg "Hellbus" or "EJ71Van" on Aussies and ask them what they're running. Nice guys
RatCamper
PostPosted: Sat May 21, 2011 6:06 am    Post subject: Reply with quote
Thanks for the info.
Under "controlled" conditions I've found the fan can keep the temperature under control when sitting stationary idling or even at about 2500RPM (Jump starting the DD when it's having an "episode"). Bigger would be better for sure though. I have a couple of larger ones but they don't physically fit because they are from a Mitsubishi and had no reason to be small.
PostPosted: Sun May 22, 2011 12:47 am    Post subject: Reply with quote
Totally off topic..love your stickers but where's the "Aussievedubbers" one? Even I have one of those - highly treasured!
RatCamper
PostPosted: Sun May 22, 2011 6:26 am    Post subject: Reply with quote
I know it's OT, but here's the lot:
I don't have an AVD one, nor do I have a KC one even though I was one of the very first people to sign up. Something like #13. I never received the promised sticker and pretty much gave up on them for years and re signed up a couple of years ago.
I'm starting to think maybe a 12" fan would be a good idea. I don't think anything much larger would fit because the radiator isn't very high. A larger fan would probably spill over the edge.
Joel
PostPosted: Mon May 23, 2011 1:03 pm    Post subject: Reply with quote
Ah crap my bad.
Will sort one out next time I chat to you.
pretty sure I put a white one aside for you a while back
PostPosted: Wed May 25, 2011 10:39 pm    Post subject: Reply with quote
A white one Joel?
Wonder where that is?
