kev Initiate Jedi
Posted: Tue May 17, 2011 4:26 pm Post subject: fuel tank |
evening all
im just about to start putting a ej20 1996-98 into my 1978 panel van
ive got most of my gear from rjes
i think i understand most of what is involved but im just struggling to work out what i need to do with my fuel tank i have got a bosch pump from rjes
any pictures and advice much apreciated
cheers kev
has anybody got a scoop on a lowered van im just wondering how low the scoop actually is |
splitbus67 Padawan
Posted: Tue May 17, 2011 8:33 pm Post subject: |
| Just doing my tank. You need a 12mm outlet to feed the fuel injection pump and an 8mm return from the fuel rail back into the tank, mine is going in the front of the tank near the top, I believe some put the return into the filler neck tube as its less risky to install. |
kev Initiate Jedi
Posted: Wed May 18, 2011 7:59 am Post subject: |
thankyou for the reply and information do you or anybody else have any picture please
cheers kev |
B4Tfink Jedi Knight
kev Initiate Jedi
Posted: Thu May 19, 2011 6:56 am Post subject: |
thanks for the link
sorry i didnt do a search first |
splitbus67 Padawan
Posted: Fri May 27, 2011 9:37 pm Post subject: Fuel Tank Modifications 67 split |
Here some photos of my tank
Top pipe is the return to the tank
Bottom pipe is for the night heater
Pipe left to right is from the tank overflow
Outlet has been modified by welding 9mm pipe into the original tank outlet fitting.
1303Steve Jedi Knight
Posted: Fri May 27, 2011 10:11 pm Post subject: |
Hi
Wouldn't it be better to source factory EFI tank from that model bay, they have a built in surge tank.
Steve _________________ STI powered 1303 now running
Posted: Sat May 28, 2011 12:08 am Post subject: |
| 1303Steve wrote: | Hi
Steve |
Nah, that means spends.
Could be well spent on beer/petrol knowing you've done a good job
Kev, you know the link I gave you earlier...around the page 26 mark? Well look around there for my posts "my conversion so far" "part xxxx" etc. I'm sure you'll find all you need to know.
Oh avoid my first header, you want a Frontera tank _________________ The advice you receive on here is worth the paper it's written on.
