67' U.S Style Bug - Subaru N/A ej20
Goto page Previous  1, 2
P4UL
PostPosted: Sun Feb 13, 2011 10:02 am    Post subject: Reply with quote
Job well done
PostPosted: Thu Feb 24, 2011 8:45 pm    Post subject: Reply with quote
and so you should be pretty happy that looks spot on mate
You've certainly set yourself a high standard hope you stick with it
Keep it up
Shrek
PostPosted: Fri Feb 25, 2011 9:57 pm    Post subject: Reply with quote
Thanks Lads, I've been a bit busy lately but had a chance to start on the front mounted Rad.
Heres what it looks like so far.
Made a surround for the radiator to sit in (pipes and fan mounted behind)
Still needs finishing at the bottom + I'll need to make a front scoop and some sort of front cover - Should be soon, so watch this space Happy
Shrek
PostPosted: Sun Mar 06, 2011 7:34 pm    Post subject: Reply with quote
Not much progress lately but will have radiator sussed soon!, started to clean wheels up. Had a bit of a mad moment and thought of fitting different wheels but have found a place that will narrow the fronts, so I'll get some turning circle back!. Here's a pic of wheels so far Happy
Shrek
PostPosted: Thu Mar 10, 2011 7:03 pm    Post subject: Reply with quote
Wheel with a bit of paint on it!. What do you think?. Happy
Will definitely need lacquering but wanted to see how it looked.
Shrek
PostPosted: Thu Mar 10, 2011 7:43 pm    Post subject: Reply with quote
P.s - Made a bit of progress with the radiator Wink
Just need to make an air scoop for underneath.
vw66wrx
PostPosted: Fri May 06, 2011 1:31 pm    Post subject: radiator Reply with quote
is that a peugeot radiator? one from a 206?
1966 LHD Bug WRX Conversion
easy-does-it
PostPosted: Fri May 06, 2011 7:32 pm    Post subject: Reply with quote
Rad looks identicle to the one i just changed in the polo...
Some very nice fabrication going on dude Happy
'76 bay going superfly TDI
Shrek
PostPosted: Sat May 07, 2011 12:03 pm    Post subject: Reply with quote
Thanks for the comments - It is a Polo rad
I went for that one as I thought that if it was good enough for Caterham to use in there cars then it would do for my Bug Happy + you can get a nice uprated alloy race one the same size!!
Page 2 of 2
