Starter motor upgrades?
Rapidresto
PostPosted: Tue Apr 05, 2011 9:19 pm    Post subject: Starter motor upgrades? Reply with quote
Ok i've been having starter issues which i hope has been traced to an electrical problem keeping the starter engaged and trashing the motor (twice).
Before i replace the stock motor again, i was wondering if there are any better alternatives.?
I'm running a stock swingaxle ghia/bug box with a DS tuning adaptor plate and flywheel, to an ej22.
I've been looking into the westyventures.com adaptor to allow t25's to use a tdi starter but they can't tell me if they will work with my box.
Anyone know if a t25 starter is compatible or been sucessful in using the tdi starters or can anyone suggest something else?
I've got to get another motor now anyway (my last spare seems to be duff), but don't want to go mad on cost incase the motor trashing hasn't been solved yet!
John
1303Steve
PostPosted: Wed Apr 06, 2011 12:12 am    Post subject: Reply with quote
Semi auto bug starters are a little stronger than stock manual ones. I used one with my old 1302 WBX that was running 10.5:1 comp and it really kicked over quickly.
I'm now running a high torque starter I bought form Pelican parts in the US.
Steve
STI powered 1303 now running
Joel
PostPosted: Wed Apr 06, 2011 12:16 am    Post subject: Reply with quote
I ran the stock beetle starter with my EJ22 for a few months and it managed fine, slowed a bit when the engine was hot but always started.
A VW freind had a brand new German bosch starter for a semi-automatic beetle which is higher HP than stock and self supporting so I grabbed it.
When I looked on the box it was actually for a 83-88 automatic vanagon/caravelle/transporter whatever the boxy T3s are known as but he said it's identical to a semi auto starter.
been working well for 18 months now
Rapidresto
PostPosted: Wed Apr 06, 2011 7:09 am    Post subject: Reply with quote
thanks guys.
The auto starters seem to be the same over the years but the bug&bus starter changed in 75 and again in 81.
Joel does the auto starter just bolt up to the swingaxle box or does it need any mods?
Joel
PostPosted: Wed Apr 06, 2011 11:22 am    Post subject: Reply with quote
bolts straight up
Rapidresto
PostPosted: Wed Apr 06, 2011 8:35 pm    Post subject: Reply with quote
hmmmm i'll look for one of them.
I wonder if i could use the auto version of the westyventures.com tdi starter adaptor?
Obonobo
PostPosted: Fri Apr 08, 2011 9:24 am    Post subject: Reply with quote
Hi John,
I'm not sure whether it is relevant, but it might help: An acquaintance of mine blew a couple of starter motors (Citroen AX from the late nineties), because the earthing/ground of the box wasn't good. Actually, it was hardly there. The starter motors couldn't release excess current (or something like that anyway) and melted. A new groundstrap to the chassis from both the box and the engine and stripping the chassis where they bolted on worked wonders.
Goodluck!
Greetings from Sietze
Rapidresto
PostPosted: Fri Apr 29, 2011 8:15 am    Post subject: Reply with quote
Right, quick update on this!
I've searched for a reasonable priced auto starter with no joy (i'm not going to spend too much as i've been munching them too much recently!).
So i've borrowed a tdi starter adaptor from a friend www.westyventures.com it's the auto version and using a starter from a mk4 golf TDi and it fires up no problem and works a treat, real strong starter.
So far so good. Unless there's a mechanical reason (like it's not fully engaged and going to wear out the cogs) then it seems to work great.
So a starter adaptor from westy ventures (the auto version) and a mk4 golf tdi starter is a cheap alternative to a high torque / auto starter for swingaxle gearboxes and scooby conversions.
Still some head scratching to do though. I've added some earth straps anyway but that wasn't the issue. It turns out i'm getting a positive feed back from the ECU to the starter keeping it engaged but only a little while after the engine is started i'm going to do some more research and post a new topic on that if no joy.
vw66wrx
PostPosted: Sat Apr 30, 2011 3:03 pm    Post subject: Reply with quote
hello mate, i know it has been a while since you posted this thread but do you know the part number for the starter as i am considering the same conversion for my install. i have looked on ebay and came across these:
http://cgi.ebay.co.uk/VW-GOLF-MK3-MK4-1-9-D-SDI-TDI-STARTER-MOTOR-/220776950454?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item336754eab6
http://cgi.ebay.co.uk/VW-GOLF-MK4-1-9-SDi-TDi-1997-04-STARTER-MOTOR-ST113-/230614914443?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35b1b8558b
do you know which would be best and is the conversoin still running fine?
Thanks
Mark
1966 LHD Bug WRX Conversion
Rapidresto
PostPosted: Sat Apr 30, 2011 4:08 pm    Post subject: Reply with quote
its the manual version of the TDI starter you need not the auto version.
Part number is 02A 911 024 or 02A 911 023R
