Metal Cutting Circular Saw Blade
Post new topic   Reply to topic     Forum Index -> Useless Information
PostPosted: Fri Aug 11, 2006 11:47 pm    Post subject: Metal Cutting Circular Saw Blade Reply with quote
I bought an "Elovution Rage - Multipurpose S.A.W. (TM) blade" in B & Q last Sun. Approx £20 for yer hard earnt.
Bung it in a circular saw, chuck on some goggles, gloves and a long sleeved top (#1) and cut through 3mm MS plate. Job done Grin
Will cut steel up to 6mm, cast iron, ally, copper, wood, MDF, blah, blah....
#1. It chucks out red hot chips which are sharp. I have a few burn marks on my arms & some cuts on my hand from the chips.
Beats using a cutting disk in a grinder. I don't know how long it will last though.
pepper
PostPosted: Sat Aug 12, 2006 11:33 am    Post subject: Reply with quote
So you just bunged one of those blades into your normal saw then?
If so am popping down to pick one up!
PostPosted: Sat Aug 12, 2006 6:32 pm    Post subject: Reply with quote
Yup. TBH though I did buy a new saw as mine was very old and tired
B & Q were actually cheaper than Machine Marts catalogue price.
Personally I think B & Q should be done for false advertising ie "Permanantly low prices" Yeah, riiiiiight.
famous phil
PostPosted: Sun Oct 15, 2006 12:23 am    Post subject: cutting blade Reply with quote
Hello yes sounds a bit gash whats the blade look like ,, big teeth or small ,, i know when useing a sthill saw with metal cutting blades to cut up scrap vans , they tend not to last long ,, so what i use is a worn diamond blade , , remember safty and wear all relative P.P.E Cool ,,, and extiguisher also the particles that fly off when cutting can be traveling at 80 meters a second that hurts then it burns you
Post new topic   Reply to topic     Forum Index -> Useless Information All times are GMT
