tracktony Initiate Jedi
Posted: Sun Apr 03, 2011 8:40 pm Post subject: Wiring help |
Hello
I am posting on behalf of Tony as i am finishing off the coversion on hus bus for him, however i have run into a small problem with the wiring.
We have 2 lots of 3 wires left that we are unable to remember where they origionally went...
The 1 bundle of 3 wires exit the main body of the bus into the engine bay through one of the gromets on the off side
This contains the following wires:
1 x Blue with green flash
1 x Brown with green Flash
1 x Thick black
Second set is from just behind the off side rear light below the test connection box and again has 3 wires:
This contains the folowng wires:
1 x Brown with white flash
1 x Brown with red flash
1 x Brown
Can anyone tell me exactly what these wires do as this is pretty much all that is holding the final wiring of the conversion as i have never worked on a VW bus before and am a little reluctant to cut all the wiring open to chase the wires..
Thanks for taking time to read this and hope you can offer some help!
James (on behalf of Tony!) |
Posted: Mon Apr 04, 2011 10:57 pm Post subject: |
Top 3
1 x Blue with green flash Oil Pressure warning light
1 x Brown with green Flash ?
1 x Thick black 12V to coil (Turns on with IGN) - I think
Can you tell us what year and what engine was in the bus? _________________ The advice you receive on here is worth the paper it's written on.
Joel Jedi Master
Posted: Tue Apr 05, 2011 7:07 am Post subject: |
The brown with green flash in with the coil and oil pressure wire you will probably find is grey with green, they just go brown with age.
Thats just a diagnostic wire, doesnt do anything
I've had no experience with bus wiring but i'd make a bet that:
1 x Brown
Thats the wiring to the heater booster fan that sat above the engine. _________________ 1974 1303 Germanlook Suba-Beetle
Posted: Tue Apr 05, 2011 3:44 pm Post subject: |
1972/73 1600tp
mk3 golf gti engine going in with full lpg conversion |
gazman Padawan
