Help me fellas... Scooby or ford conversion
Davecrook1
PostPosted: Sat Feb 12, 2011 9:07 pm    Post subject: Help me fellas... Scooby or ford conversion Reply with quote
Can't decide.. I fancied a scooby but found ford to be more straight forward..
But looking at the scooby, I can make. Reverse throttle body and shorten the sump myself and get all the bits I need for £200 then an adapter flywheel and clutch for additional £450
ford wise, I can get an adapter kit for around £150 plus then a decent pinto that's been rebuilt with webers for £350-400...
So I'm stuck what to...
Shrek
PostPosted: Sat Feb 12, 2011 10:01 pm    Post subject: Reply with quote
Hi bud, just answered your other post and seen this one!.
The ford would prob be easier, if you ask me as you won't need to fit new fuel pumps or modify the tank(efi). Although they are quite thirsty on twin webbers if fitted! Eeeek .
Subaru on the other hand, for me if maybe a bit more expensive - is more compact and reliable. If you have the room then why not just buy an adaptor kit and an mot failure 2.5ltr legacy(150+bhp)?.
Happy
Davecrook1
PostPosted: Sat Feb 12, 2011 10:28 pm    Post subject: Reply with quote
Well I hav sourced an adapter kit and spoke to a chap with a Subaru sport.. Has all the parts I need for £200 and he's not fat from me either.. Realistically I'd buy a scrap motor but already got three cars on the front of my hse and my folks wouldn't let me take it to theirs either lol..
Shrek
PostPosted: Sat Feb 12, 2011 10:44 pm    Post subject: Reply with quote
Thats what motor I've got - 2.0ltr impreza sport, sounds like a good deal to me but make sure you get everything as in complete loom, ignition, fuel pump. would be usefull if you marked up wiring from the car before it was removed if you can (Ie neutral switch, fuel pump etc..)
PostPosted: Sun Feb 13, 2011 12:41 am    Post subject: Reply with quote
ide get your arse up to newmarket and buy it you would be home by dinnertime Wink
Davecrook1
PostPosted: Sun Feb 13, 2011 11:20 am    Post subject: Reply with quote
Laugh Out Loud I might be heading to Newmarket yet
he has most things other than lamba sensor and fuel pump! But they shouldn't be too hard to source should they??
This is what he has and hasn't got.. He's put yes and no nxt to them.. What else would I need
Dear davecrook1,
anciliaries
inlet manifold yes
exhaust manifold yes
all sensors, esp MAF sensor and lambdas, yes no lambda
alternator yes
mounting rubbers, yes
engine wiring harness, yes
ECU, yes
fuel system parts (filter etc), no
chargecooler (complete with pump and Rad) yes
complete loom and ECu from the car - just the transponder yes
(chip), immob unit and ariel to go with your ECU yes
engine to gearbox bolts as they are an odd pitch no
Flywheel, yes
pressure plate, yes
release bearing, yes
starter,yes
PostPosted: Sun Feb 13, 2011 11:43 am    Post subject: Reply with quote
Dear davecrook1,
anciliaries
inlet manifold yes
alternator yes
ECU, yes
fuel system parts (filter etc), no (golf gti)
engine to gearbox bolts as they are an odd pitch no ( not needed)
Flywheel, yes ( not needed)
pressure plate, yes ( not needed)
release bearing, yes( not needed)
starter,yes( not needed)
the parts ive put (not needed) against if you are using a plate conversion,you only need them if using bellhousing conversion ,and ive suggested a fuel filter Grin [/b]
Davecrook1
PostPosted: Sun Feb 13, 2011 1:56 pm    Post subject: Reply with quote
Nice one..what fuel pump do you suggest?
Is the rest ok on the list though? I don't need anything else do I?
PostPosted: Sun Feb 13, 2011 2:08 pm    Post subject: Reply with quote
a 3 bar pump off an audi or bmw is ok ,or an after market bosch.
there is always something else but nothing that stands out Wink
is the sport a turbo engine?
Davecrook1
PostPosted: Sun Feb 13, 2011 2:31 pm    Post subject: Reply with quote
No I think the sport is 160bhp Non turbo motor...
PostPosted: Sun Feb 13, 2011 2:32 pm    Post subject: Reply with quote
so charge cooler and pump?
Davecrook1
PostPosted: Sun Feb 13, 2011 2:42 pm    Post subject: Reply with quote
I did wonder.. I copied the list off another thread.. Chargecooler beinnthe intercooler?? What's the pump?
