Yes I have a warning light for the big Fan, the smaller one is controlled via the ECU so I leave that alone.
Warning light only gives a short warning, only had a fuse blow once whilst on the motorway and it got hot very quickly! _________________ 66 Camper with 2.2 Subaru
63 Triumph TR4 with Rover V8
Posted: Fri Jan 28, 2011 4:48 pm Post subject:
What you can do Neil is add a light to the +ve side of the fan & to ground.
If the light's on...the fan's running. If it's off but you *know* it should be on - you have a blown fuse/broken fan _________________ The advice you receive on here is worth the paper it's written on.
