1975 bay scooby con please advise
Goto page Previous  1, 2, 3, 4, 5
Neil-C
PostPosted: Fri Jan 28, 2011 9:27 am    Post subject: Reply with quote
Rad in the back works for me.
I have been running this set up for 10 years now with no issues.
BUT as said it does rely on the fans, which are on a lot, so as long as they are fed with electricity I see no problem.
[/img]
66 Camper with 2.2 Subaru
63 Triumph TR4 with Rover V8
PostPosted: Fri Jan 28, 2011 2:37 pm    Post subject: Reply with quote
FANtastic.... I'll get my coat.
Do you have any warning lights in the van if the fans aren't working Neil?
Neil-C
PostPosted: Fri Jan 28, 2011 3:39 pm    Post subject: Reply with quote
Yes I have a warning light for the big Fan, the smaller one is controlled via the ECU so I leave that alone.
Warning light only gives a short warning, only had a fuse blow once whilst on the motorway and it got hot very quickly! Eeeek
PostPosted: Fri Jan 28, 2011 4:48 pm    Post subject: Reply with quote
What you can do Neil is add a light to the +ve side of the fan & to ground.
If the light's on...the fan's running. If it's off but you *know* it should be on - you have a blown fuse/broken fan Happy
Punky
PostPosted: Mon Jan 31, 2011 8:51 pm    Post subject: Reply with quote
Volvo SV40 2l rad going under the van. £45 off ebay
Page 5 of 5
