Don't reduce the diameter of VDO water temp sensors
PostPosted: Wed Oct 11, 2006 2:41 pm    Post subject: Don't reduce the diameter of VDO water temp sensors Reply with quote
Mate said it was ok to reduce the dia of a VDO sender (part no 47 001 060, 120°C) from 8mm to 7mm. Apparently this works with some senders quite happpily. He's filed a few in his life.
The bulb is just that bit too big to go into a Subaru manifold. Thought I'd post it here as there might be others with different engines wishing to do this.
I got a mate to spin it up in a jewellers lathe.
It fecks up the VDO ones as the wall thickness is approx .5 mm. The end pinged off .
A picture will follow (can't find the hosting bit at the mo)
(edit: found it)
Last edited by ElusiveStranger on Fri Oct 13, 2006 1:19 pm; edited 1 time in total
Cleverchap
PostPosted: Wed Oct 11, 2006 4:06 pm    Post subject: Reply with quote
Arse.
How small is a jewellers lathe.....sounds minute
PostPosted: Wed Oct 11, 2006 6:55 pm    Post subject: Reply with quote
Cleverchap wrote:
Arse.
Coupla foot but it's for doing small stuff.
Anyway good news, I've drilled the manifold to 8.5mm - it was more of drill the ally oxide on the lower portions of the thread. Can hardly see where it's drilled TBH.
New sender should be here tomorrow <crosses fingers> if not it'll be here Fri.
That means packing the van tomorrow night, driving to work in the bug, coming back, fitting sender, top up water & down to Devonshire
PostPosted: Thu Oct 12, 2006 9:48 pm    Post subject: Reply with quote
Sender arrived today and fits. Approx 4° out.
Gotta recommend ETB Instruments for their fantastic service.
£10.12 for the sender
£1.50 postage
Can't say fairer than that
www.etbinstruments.com
