1975 bay scooby con please advise
Goto page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed Nov 24, 2010 11:13 pm    Post subject: Reply with quote
Punky wrote:
its a bit of scary driving around and watching the temp gauge on the dash rise above 250f /121c which should be about right to blow up. however i stop check the temp of the water and its cold enough to touch in the header tank the manifold is warm to the touch and the engine bay is pumping out alot of heat. we had a external tester and checked the manifold temp every time it got hot and it only read 90c so it must be the sender gauge in the engine block ???
Was the sender matched to the gauge?
Any diagrams of your cooling system?
Saying the header tank is warm doesn't mean much if we don't know anything about the system
PostPosted: Thu Nov 25, 2010 10:03 am    Post subject: Reply with quote
i would email the gauge supplier with part numbers to double check? its all to easy to get the wrong sender, on my van it was a brand new vdo gauge with new vdo sender and they still didnt work together as there was about 10 different resistances in that thread Eeeek do you have non contact thermometer? if you have try reading at different point on the engine & hoses to see how hot its gettting and to see if the stats opening ok?
Punky
PostPosted: Sun Jan 23, 2011 7:54 pm    Post subject: Reply with quote
Well just got a new temp gauge with new sender fitted it this weekend and have come to the conclusion that the rad position is poo! not working temp gets to 90c very quick the fan kicks in nice but as soon as you hit the A34 it will reach 100c in about 10 minutes and i have to stop and let it cool down. Have to re think that rad shame i wish i had listen to you guys sooner.
Well looks like its an underneath job coming up soon!
Front or middle?
I reckon there is loads of room in the middle which will save on the length of the water pipes
Punky
PostPosted: Mon Jan 24, 2011 7:26 am    Post subject: Reply with quote
Been up most of the night with this, as i have a bull bar on the front i should be able to mount a rad inbetween the two vertical bars. BUT what about air blockages ? would i have to but the header tank above the rad at the front ?
Punky
PostPosted: Mon Jan 24, 2011 8:08 am    Post subject: Reply with quote
after looking at every ones ideas for the 100th time id rather have the rad out of sight which is why i stuck it in the back ( i am going to do a test run as it is ( how much air does get down the rear vents? ) ill get a mate to test it while driving along my problem could simply bee that the air is swirling around in back rather than going through the rad. If this is right then if i fit a ducting from the vent directly across the rad the air has no choice but to go through. Failing that plan b or c,d,e ? Who knows just want the bus working for this summer. Still got the inside to make good yet Massive set back Sad
PostPosted: Mon Jan 24, 2011 7:51 pm    Post subject: Reply with quote
Double sweet FA basically. Remember in the VW it had a dirty great sucker fan
Punky
PostPosted: Mon Jan 24, 2011 8:33 pm    Post subject: Reply with quote
Balls! never-mind means i can have more fun spending money i have not got! fixing a problem which i should have sorted out first Cheers
Punky
PostPosted: Tue Jan 25, 2011 8:48 pm    Post subject: Reply with quote
Ok BUT what if i do this and add a bigger air scoop on the side. i think its worth a go before i rip it all out and start again.
PostPosted: Tue Jan 25, 2011 10:05 pm    Post subject: Reply with quote
You could try a big scoop underneath near the torsion tubes and duct/direct it to the rad
easy-does-it
PostPosted: Wed Jan 26, 2011 7:22 pm    Post subject: Reply with quote
This should be the quote of my entire build Laugh Out Loud
..move the rad dude, i wouldnt even waste the time and effort with it out back (plus even with an inspection hatch it's going to be tough getting to anything just to sevice it)
'76 bay going superfly TDI
obi1robi
PostPosted: Wed Jan 26, 2011 11:40 pm    Post subject: Reply with quote
wondered when we would hear from you EDI...yes front is best but maybe not the simplest..
check out mine:
scotty give me warp speed
easy-does-it
PostPosted: Thu Jan 27, 2011 7:25 pm    Post subject: Reply with quote
Me sir? I was thinking more of underneath for the simplest and quickest way..
....although out front inbetween or just behind the roo bars would work for me...
I wont show you mine, it's like obi's ...just not as clean
Page 4 of 5
