vwrx running problem?
BlackCosmos
PostPosted: Wed Dec 29, 2010 7:06 pm    Post subject: vwrx running problem? Reply with quote
I have an early wrx fitted in a t25,since being colder weather the cooling fans run as soon as its running..havnt driven it like this..any ideas??[/i]
james72
PostPosted: Wed Dec 29, 2010 9:21 pm    Post subject: Reply with quote
Maybe the temp sensor ? if it's shagged then the ecu will switch the fan on just in case. Got any error codes?
1989 VW Magnum Multivan EZ30
PostPosted: Thu Dec 30, 2010 3:41 am    Post subject: Reply with quote
If it's as soon as you turn it on it'll be a temp sensor fault or the wiring's got a break in it leading to the ecu. The fail mode is to run the fan.
BlackCosmos
PostPosted: Thu Dec 30, 2010 3:17 pm    Post subject: r Reply with quote
The temp gauge works fine,take it means sender ok..did fault check and coolant sensor came up..its also hard to start..takes a while to fire??[list=][/list]
james72
PostPosted: Thu Dec 30, 2010 7:13 pm    Post subject: Reply with quote
The temp/coolant sensor talks to the ecu, the sender which is next to it, on the coolant manifold controls the gauge. Replace the sensor not the sender the sensor is the bigger one 17mm iirc
PostPosted: Fri Dec 31, 2010 3:03 am    Post subject: Reply with quote
The temp sensor I mentioned is the one going to the ECU, not the gauge.
If the sensor (twin pin, usually Brown plastic) goes open circuit (or is it closed on fail) causes the ECU to turn on the fans. That's the "fail safe" mode.
"Takes time to fire". Sounds like you haven't got the cold start wire connected to the solenoid.
BlackCosmos
PostPosted: Fri Dec 31, 2010 9:29 am    Post subject: Reply with quote
Right hung another sensor on,but still the same...it ran fine last winter. .wheres cold start valve? I left ecu disconnected overnight. .I,ll check codes again..
BlackCosmos
PostPosted: Sun Jan 02, 2011 9:21 pm    Post subject: Reply with quote
quick update..removed all power from ecu for 36hrs,reconnected and bingo..seems fine..started up first crank and no cooling fans running..hope to use it tomoz..thanks for advice..happy new year!!
