Subaru EJ20 N/A Engine conversion
Goto page 1, 2, 3  Next
Shrek
PostPosted: Sat Nov 27, 2010 12:13 pm    Post subject: Subaru EJ20 N/A Engine conversion Reply with quote
Hi, have just joined today , have a 73' 1200 with project fitted with a 99' 2.0 non turbo impreza engine(kennedy adapter/flywheel) - not running yet as I'm having a bit of chew with the ecu wiring. Has anyone fitted one of these and could help?. Cheers Shrek
PostPosted: Sun Nov 28, 2010 2:12 am    Post subject: Reply with quote
Ummm hit the search button. Read the threads, then come on back with questions.
Welcome fella Happy
Shrek
PostPosted: Sun Nov 28, 2010 2:19 pm    Post subject: Reply with quote
thanx bud I've had a look already but will go over it again to check!!!
Shrek
PostPosted: Sat Dec 04, 2010 2:06 pm    Post subject: Reply with quote
Hi, had a look through previous threads and could'nt see anything that suits my wiring problem so have added some pics to see if anyone can help . I cut the loom down myself from the one that came with the engine & ecu. Looks like chip is missing from ignition for transponder key so poss rewire to remove immobiliser ecu?. plus a couple of pics my progress so far - bodywork is about 95% complete. the style of the car is a 67' cal look with a twist (Ie 67' decklid, doors, long bonnet and US spec upright front wings but with added twist of subaru engine and 18" wheels that will be painted black and fitted under wider wings at the back and to a 4" narrower front beam upfront.
P4UL
PostPosted: Sat Dec 04, 2010 9:45 pm    Post subject: Reply with quote
Sorry cant help with the wiring, but I do like what you have done with the firewall.
I've been thinking about whether to do that in mine. Looking at your has made me realise yes I need to do it.
Any other pix?
PostPosted: Sun Dec 05, 2010 3:04 am    Post subject: Reply with quote
Ummm, missing transponder chip... not looking good - seriously. ( I do have a theory, and must try it on my van one day)
Who'd you buy the lump from?
paul_f
PostPosted: Sun Dec 05, 2010 8:51 am    Post subject: Reply with quote
I'd imagine you should just be able to replace the transponder circuit on the ignition barrel with another one. There are only 4 wires going from it to the immo ECU, so I reckon the immo ECU will be the only part that is coded to the key.
PostPosted: Sun Dec 05, 2010 7:13 pm    Post subject: Reply with quote
Sorry, hadn't noticed you had the key. As Paul said, you should be able to just get a new coil part.
PostPosted: Tue Dec 07, 2010 9:19 pm    Post subject: Reply with quote
That plug your not sure of looks to be either aiflow meter/ throttle position sensor, looks to big to be for the boost control gizmo's Grin
PostPosted: Wed Dec 08, 2010 12:11 am    Post subject: Reply with quote
I'm glad you bumped it - missed that too as was looking on my desire and hadn't zoomed in!
MAF sensor generally has 5 pins
Ignitor module, 6 pins (that's what it looks like to me)
Other does look like Lamda
Shrek
PostPosted: Wed Dec 08, 2010 4:49 pm    Post subject: Reply with quote
thanks for info, will try and get to a breakers and have a look for an ignition lock assembly once the weather picks up!. Any ideas on the two plugs that I'm trying to identify?. Ps - how do you run your engines without neutral switches?.
Shrek
PostPosted: Wed Dec 08, 2010 5:02 pm    Post subject: Silly Me Reply with quote
Hi, just seen your replies to my post after posting another reply!!!!!!
I bought the engine etc of Ebay - came out of a 98' Impreza sport that had 75,000 and had been written off after the owner had someone drive into the side whilst he was waiting at a roundabout! only cost £200 and I made the exhaust myself!.
Page 1 of 3
