just a quick clutch question
troy_1234
PostPosted: Thu Oct 14, 2010 9:49 pm    Post subject: just a quick clutch question Reply with quote
hi im about to embark on a subaru conversion in my split, i got an ej20, mounting to an AT code gearbox... now if i get a kennedy 200mm adapter kit, will i just need to buy a standard 200mm clutch?? £80 type jobby from machine7? or a specific one from kennedy? im a bit confused.
any help would be brilliant, thanks, troy.
troy_1234
PostPosted: Thu Oct 14, 2010 9:51 pm    Post subject: Reply with quote
its a 2000 year by the way
Inane Cathode
PostPosted: Fri Oct 15, 2010 1:23 am    Post subject: Reply with quote
Yeah, just stock vw clutch stuff. You really need to get an upgraded pressure plate and a more resilient clutch, though. I have some slippage and thats with a ej22 non turbo.
troy_1234
PostPosted: Fri Oct 15, 2010 9:33 am    Post subject: Reply with quote
cool thanks, so where do i get an upgraded one? could you give me a specific cause i really have no idea about clutches! thanks again.
Inane Cathode
PostPosted: Fri Oct 15, 2010 3:56 pm    Post subject: Reply with quote
I got my clutch stuff from lawn mower.net they suggested the kennedy stage II pressure plate and the copperhead clutch disk (both in 200mm).
I thought i'd be alright with a heavy duty pressure plate and the KEP gold clutch disk, but alas mine slips if you drop the clutch on it and keep shifting hard. I guess 'heavy duty' doesnt really mean much.
PostPosted: Fri Oct 15, 2010 4:04 pm    Post subject: Reply with quote
a.i.r.c.o.o.l.e.d.DOT net Wink
If you type a1rc00led on here it becomes "aircooled"
PostPosted: Fri Oct 15, 2010 10:23 pm    Post subject: Reply with quote
Laugh Out Loud
Couldn't resist
now we have a secret way to type aircooled Wink
PostPosted: Sat Oct 16, 2010 12:04 am    Post subject: Reply with quote
Git
troy_1234
PostPosted: Sun Oct 17, 2010 12:35 pm    Post subject: Reply with quote
thanks for the replies, so what set up do you think would be most suited for an ej20 to AT beetle box, pushing a bus?
ping
PostPosted: Mon Oct 18, 2010 8:41 pm    Post subject: Reply with quote
I've got a kenedy clutch black with gold bits in and a kenedy stage III pressure plate. This is going in my split on an AT code gearbox. Dont forget to put in a heavy duty clutch release arm any poly bush!
Griff71
PostPosted: Mon Oct 18, 2010 9:51 pm    Post subject: Reply with quote
Alternative to what ping suggests is chuck some more weld around the the clutch release shaft forks (the ones that hold your thrust bearing in situe). After having one break and following advice from Rich RJES that it is common. I welded mine all the way around the forks. I think VW had a single blob of weld on each side and Just Kampers even less.
It will break sooner or later![/img]
89 Crew Cab (Subaru 2.5na)
71 Drag Bug (1955cc dual 40s)
65 Ragtop Bug (low & stock)
troy_1234
PostPosted: Mon Oct 18, 2010 10:43 pm    Post subject: Reply with quote
thanks again for the replies guys, will be sure to weld that release fork up then Happy. am away at uni at the moment so will keep my eyes peeled for a second hand deal i think.
troy
