Griff71 Jedi Knight
Posted: Sun Oct 03, 2010 4:44 pm Post subject: Annoying temp gauge! |
Thought i would ask on here as i seem to be having an issue with the Crew Cab at the moment. Have tested subaru sensor and vw sensors as well as wiring and behind the dash. Have checked as per info Rich gave me sometime ago and all checks out as it should. The problem:
Every morning within 5 mins of driving and long before normal running temp is reached my temp gauge warning light starts flashing. Now the first time it happened i stopped and got out but no overheating and thankfully the head gaskets remain in tact!. Anyway i switched the motor back on and all was fine again. The problem didn't arise again until the next day same time same place. This time i quickly switched the ignition off and on and the problem stopped and as before did not arise until the next day, same time same place. So what is wrong?!
Looks like i going to have to start replacing more bits. Unless anybody has had similar issues.
Griff _________________ 89 Crew Cab (Subaru 2.5na)
71 Drag Bug (1955cc dual 40s)
65 Ragtop Bug (low & stock) |
doppelganger Jedi Guardian
Posted: Sun Oct 03, 2010 10:30 pm Post subject: Re: Annoying temp gauge! |
| Griff71 wrote: | The problem didn't arise again until the next day same time same place. This time i quickly switched the ignition off and on and the problem stopped and as before did not arise until the next day, same time same place. .
Griff |
leave earlier and take a different route  _________________ vwdrc class rep
BlackCosmos Padawan
Posted: Mon Oct 04, 2010 10:29 am Post subject: |
| mine did the same,on and off..i changed the vw one in the expansion tank and it cured it.. |
Griff71 Jedi Knight
Posted: Mon Oct 04, 2010 12:02 pm Post subject: |
Only replaced it a few months ago as i had a similar issue. Will swap back to the old one and see if it helps.
Thanks _________________ 89 Crew Cab (Subaru 2.5na)
BlackCosmos Padawan
Posted: Mon Oct 04, 2010 4:27 pm Post subject: |
| forgot to mention i found the clip connector didnt fit new one properly and it happened again and i had to cable tie it in place.. |
james72 Initiate Jedi
Posted: Wed Oct 06, 2010 5:51 pm Post subject: |
I thought that light was just a water level sensor? _________________ 1989 VW Magnum Multivan EZ30 |
