tracktony Initiate Jedi
Posted: Tue Sep 07, 2010 10:30 pm Post subject: mk3 golf gti help |
| just purchased a golf gti engine with a full lpg conversion but want to run it on petrol instead if i get rid of the lpg and go fuel injection i,ll need a ecu ? will i also need the golf loom as when i purchased the whole conversion i was told the van was using the standard bay window loom , i,m not doing the work my self but want to get things ready for the mechanic cheers |
Posted: Wed Sep 08, 2010 12:58 pm Post subject: |
depends on what year motor is from a mk1 and mk2 upto 88 will be kjet which is mechanical injection and ecu run from 88. upto 88 will have a small loom for the cold start injector and warm up regulator etc and another small loom for the transistorised ignition system, on a 88on car the ecu runs everything. You could make a loom up for the kjet motor but it might be easier to find a car to pull the loom from if your using a later _________________ 1964 rat 13 window deluxe 1Z tdi,
Posted: Wed Sep 08, 2010 9:02 pm Post subject: |
| thanks not sure weather to keep the conversion full lpgare there any advantage or disadvantages on keeping it full lpg |
Posted: Tue Sep 14, 2010 9:14 pm Post subject: |
| tracktony wrote: | | thanks not sure weather to keep the conversion full lpgare there any advantage or disadvantages on keeping it full lpg |
the advantage would be the cost of running i would imagine _________________ 1964 rat 13 window deluxe 1Z tdi,
famous phil Jedi Guardian
Posted: Tue Sep 14, 2010 9:41 pm Post subject: |
Hi , not many vehicles run Full LPG and when they do the ones I've seen normally have two LPG tanks one for the liquid the other for vapour so the engine can start from cold otherwise the vapouriser would freeze , might be best if you could upload some pics or try find the manufacturers name _________________ Auto Union Munga Jeep ,T4 2.4td , T4 2.5tdi ,Mercedes S Class on LPG , 66 splity deluxe , GP mk1, 3 type 25s 1 with 1.9dt pug engine + 1 with N/A pug engine ,,there are 6 t25s with pug power in Darlington |
Posted: Wed Sep 15, 2010 10:14 pm Post subject: |
| thanks will get some details tomoorrow when i purchased the conversion he said it was not great at starting it woold start just not tickover great fora couple of minutes |
kruger Wannabe
Posted: Sat Sep 25, 2010 7:08 pm Post subject: |
| I've fitted a gti 16v ABF engine into in a bay, from a 95 golf, in short I wouldnt bother again as there are easier engines that will fit, I can help with any questions you have though. |
Posted: Sun Sep 26, 2010 9:04 pm Post subject: |
| thanks putting the engine in november no doubt i,ll be sending u pms |
Posted: Sun Oct 24, 2010 4:36 pm Post subject: |
| kruger wrote: | | I've fitted a gti 16v ABF engine into in a bay, from a 95 golf, in short I wouldnt bother again as there are easier engines that will fit, I can help with any questions you have though. |
would have thought the abf would be a easy swap? did you fit it at 15 or 50 degree? _________________ 1964 rat 13 window deluxe 1Z tdi,
kruger Wannabe
Posted: Fri Nov 12, 2010 8:14 am Post subject: |
I fitted the ABF engine at 50 degrees, as opposed to the 15 it sits at in the golf, main problem was the distributor hitting the fuel tank, I modified the fuel tank to fit, but I'm sure there is a way of moving the distributor?
Any hints? |
