t1mreed Force Sensitive
Posted: Thu Sep 09, 2010 6:24 am Post subject: vibration |
i have just comne back from devon and done about 1000mile round trip averaged about 40+ to the gallon so in many ways thing have gone well with the conversion.
BUT
when i first did the conversion i had a bad deep tone noise at high speed 70+ assumed it was vibration so went all round the engine found i had missed an engine bolt and some bolt got a bit of a tighten.
i ahve got back from my trip and the problem has returned, i have checked all of the engine bolts and every thing appears OK, nothing loose
any idears , could it be the flywheel loose? and ifso can it be check without taking the engine out?
please help |
famous phil Jedi Guardian
Posted: Tue Sep 14, 2010 9:17 pm Post subject: |
Hi , I've noticed a lot of resonance at this speed on some , sometimes its just down to the engine mounts . depending on gearbox ratios the noise starts about 68mph and disappears about 76mph , Oil filled mounts dampen the noise quite a lot _________________ Auto Union Munga Jeep ,T4 2.4td , T4 2.5tdi ,Mercedes S Class on LPG , 66 splity deluxe , GP mk1, 3 type 25s 1 with 1.9dt pug engine + 1 with N/A pug engine ,,there are 6 t25s with pug power in Darlington |
Posted: Wed Sep 15, 2010 7:35 am Post subject: |
had the same on my tdi split swapped to oil filled hydro mounts and the noise dropped away on the motorway and was much smoother at idle _________________ 1964 rat 13 window deluxe 1Z tdi,
Posted: Wed Sep 15, 2010 8:45 am Post subject: |
thank you that sounds like the way forward, i have never heard of hyrdo mounts ? where do i get them from and /or what car are they used on.
Thank you for the feedback. am loving the diesel torque and power. just did a 1000 mile round trip to devon and averaged 45mpg
tim |
Posted: Thu Sep 16, 2010 7:28 am Post subject: |
mine came from a golf tdi but audi are favourites _________________ 1964 rat 13 window deluxe 1Z tdi,
