audi gearbox in a bus
trev
PostPosted: Sun Aug 08, 2010 10:18 pm    Post subject: audi gearbox in a bus Reply with quote
I've done a search and come up with nothing soooo....
can the longitudinal gearbox from a recent Passat/Audi A4 etc be used in a bus? I understand that the diff probably can't be flipped but the whole box could be if the breather was plugged and the box filled with oil and an expansion tank used.
would the engine bolt back on to the upside-down box or would an adapter still be needed? It would be a cheap way to a nice low-revving 5 speed gearbox.
illzlee
PostPosted: Mon Aug 09, 2010 11:48 am    Post subject: Reply with quote
would the linkage not be back to front? could make for a very interesting gear change pattern
trev
PostPosted: Mon Aug 09, 2010 12:06 pm    Post subject: Reply with quote
small price to pay for a nice lazy fifth gear. You'd get used to it. Wink
so are there any major pitfalls to a conversion like this? I presume mounting it would be interesting but with the engine supported by its own bar/mounts then just a nose mount would be needed, the engine and box could be fitted up as one unit.
PostPosted: Mon Aug 09, 2010 7:34 pm    Post subject: Reply with quote
been done before was talking to someone at vanfest 08 who had done in with audi 100 box and a 5cylinder 2.2 petrol in a t25 he cut the last 25mm of the bellhousing flange and had it tig welded back on upside down
