pastaboy Force Sensitive
Joined: 28 Apr 2009 Posts: 10 Location: Invercargill New Zealand
Posted: Fri Jul 30, 2010 11:15 am Post subject: New Idea for Volkswagen / Subaru Flywheel |
Hi all ... for those yet to do their conversion I may have an alternative idea for your flywheel ... I was nervous about welding my flywheel so got a local turning shop (the people who made up the worlds fastest Indian bikes for the movie) ... to cut the centre out of my VW flywheel and make a new flanged fitted cetre that is held in by 6 (locktite fitted) machine screws with the Subaru PCD 8 hole centre ... this is one of the neatest conversions I've seen and only weighs 15 lb or 6.8kg ... so I'll put up a few photos.
Oops can't see how to attach photos can someone tell me how _________________ I always wanted to be someone ...
Now I realise I should have been more specific  |
Posted: Fri Jul 30, 2010 2:53 pm Post subject: photos |
Here's the photos I promised ... _________________ I always wanted to be someone ...
Posted: Fri Jul 30, 2010 2:55 pm Post subject: try again |
Posted: Fri Jul 30, 2010 2:57 pm Post subject: another pic of flywheel |
[img] [/img] _________________ I always wanted to be someone ...
Posted: Fri Jul 30, 2010 3:00 pm Post subject: back of flywheel |
Posted: Fri Jul 30, 2010 3:03 pm Post subject: last one |
Posted: Fri Jul 30, 2010 6:17 pm Post subject: |
Looks like a very neat job. What sort of cost was that?
Looking forward to seeing the convo & how it performs. _________________ The advice you receive on here is worth the paper it's written on.
ricola Jedi Master
Posted: Fri Jul 30, 2010 7:27 pm Post subject: |
Is the subaru ring gear the correct size for a VW starter motor? _________________ http://www.ricola.co.uk |
ttriebler Padawan
Posted: Sat Jul 31, 2010 7:06 am Post subject: |
no it's not Rich. The Subaru ring gear is bigger that a vw bellhousing! _________________ Reversed gears for Subaru Transmissions
www.subarugears.com |
Posted: Sat Jul 31, 2010 7:56 am Post subject: |
It's still the Volkswagen Flywheel and ring gear with a new centre with the Subaru 8 hole PCD flanged and bolted to it ... was originally going to weld it on but my mate doubted the safety of welding to original flywheel as although it's a great quaility casting and could be welded with a cast arc rod there's still a chance of it stress cracking under load ... He suggested this method which I think looks neat as and strong and reliable wanted to share it ... He'll let me know what it cost on Tuesday so will keep U posted
Marc M _________________ I always wanted to be someone ...
sven Jedi Guardian
Posted: Sat Jul 31, 2010 9:26 am Post subject: |
Looks like a very very nice piece of work. I hope they loctited the bolts though...
Most Volvo-converted VW buses here uses the same concept. There are two or three workshops that makes the flywheel as a service. But I think they weld 'em, not sure on that but I know at least my friends bus has a welded flywheel. |
Posted: Sat Jul 31, 2010 9:42 am Post subject: |
Yes was a pressed neat fit then all bolts locktited in ... What sort of Volvo motors are they running _________________ I always wanted to be someone ...
