Narrowing Steering racks?
Bugsy_malone 666
PostPosted: Tue May 04, 2010 10:20 pm    Post subject: Narrowing Steering racks? Reply with quote
Obviously not the centre rack, but more the end tie rods.
I have a Polo Rack that I am going to fit to a beetle and I have found its about 3-4" to wide total, so the idea is that I want to cut a bit off the tierods to make it narrower, however its going to need some more threads if I want to do that and when I looked at the existing ones it appears they are the extruded thread type so I cant just get a die on it and cut some more!
Any advice?
Also how on earth do you adjust the lock of a steering rack? Obviously with a beetle steering box there are bolts on the pitman arm to act as stop locks, but what do you adjust on steering racks?
Second Gear All The Way Baby!
Doing Thing Differently.
famous phil
PostPosted: Wed May 05, 2010 10:29 pm    Post subject: Reply with quote
Hi , what you'll find is that the steering rack does not adjust because its normally a lug or bolt on the hub Assembly Happy
if you strip the gaiter off the rack the arms might then be removable , there may be more threads to trim Happy
Bugsy_malone 666
PostPosted: Wed May 05, 2010 10:38 pm    Post subject: Reply with quote
I'm pretty sure type 3s have the stops on the hubs too, guess I'll have to look at my mk3 golf and come up with ideas!
with regards to talking the gator off to get more threads, I'm not sure I follow.
The tie rod is like this:
so the only threads for adjustment are at the trackrod end, where the threads are extruded rather than cut into the rod, meaning if I cut a bit off the end to shorten it I cant add any more threads that I need. The other end obviously screws into the rack itself.
famous phil
PostPosted: Wed May 05, 2010 10:53 pm    Post subject: Reply with quote
Happy Hi, its not how I expected it to be , that tie rod looks just the same as fitted to a t25 , may-be messure up one off a lupo ?
PostPosted: Thu May 06, 2010 7:32 am    Post subject: Reply with quote
what polo steering rack? that looks like a mk4 a mk3 centre pin type would be better in a bug wouldnt it? if you are using a mk4 type get it in lathe through head stock and get it threaded down further? there are no rack stops on a golf or mk4 polo or rack or hubs on some sporty cars that i've fitted big wheels to they have come with sleaves that go on the end of the rack before the rack ends to limit steering lock
Bugsy_malone 666
PostPosted: Thu May 06, 2010 8:10 pm    Post subject: Reply with quote
well I think the racks off a 1996 diesel polo, the tierod in the pic is just an example, but mine looks pretty much like that. I might have to see how it works, then take it to bits and take the rods over to my local engineering shop to see what they can do about addin threads.
And I think I know what you mean about the sleeves for lock, I have been looking at bit on internet and there seems to be for some where you put different thickness washers in and all sorts.
I just hope the tierod ends themselfs are the same fitment on the polo as the beetle!
If not I considered chopping the end off the rod, the end of a beetle rod (as its hollow tube) and then welding the pair together, that way it would use stock rod ends! But I'll see if I can get it lathed first.
The other fun part is going to be the fact its on a beetle with a beam, meaning I need to invent something to connect the column to the rack, plus I need to rebuild the column so its got a bearing at the bottom as well as the top!
PostPosted: Thu May 06, 2010 8:41 pm    Post subject: Reply with quote
i would use a mk1/2/3 polo steering rack if it was me as the steering arms are longer as they are centre mount so the arm angle change's will be seveer with the change in ride hight as the trailing arms arc in the opposite direction to the rack arc.
i used to work for ford many years ago and the big rs option wheels for fiesta and puma's etc used to come with rack spacers to stop the rack traveling as far and tyres scrubbing on the inner arches they just looked like a thick washer that fitted under the rack boot behind the tie rod
the mk4 polo and mk2 golf are basically the same car underneath and i've fitted a mk2 golf one in a bay hub so wont be far off. if they are to thick (which i think thet will be) but the right taper angle try a mk1 golf trackrod end as there thiner and a lot of late bug early mk1 stuff will interchange
welding any suspension part like a tierod is doddgy and welding a suspension/steering component is a mot failure
the mk2 golf only has a bearing at the top in the cast lock housing but has a push in plastic bush at the bottom of the column try 1 of those
Bugsy_malone 666
PostPosted: Thu May 06, 2010 10:44 pm    Post subject: Reply with quote
well yes the welding part I want to avoid.
I think I saw on a volksrod someone fitted a nylon bush of some sort at the bottom, I do have a 1302/03 column but its a bit short, hoever I can use the bearing out the bottom I just need to check some sizes.
when you say about the rack being centre mount, is it a bit like the 1302/3 where the arms are the same length side to side but attach with a tierod end in the middle? I'm sure I have seen audis with those.
I have ended up with the mk4 rack because it was £12.99 delivered on ebay, cheapest I seen so a good start at least!
PostPosted: Sun May 09, 2010 3:38 pm    Post subject: Reply with quote
yes thats the ones the polo is simlar to the last of the 1303's with the steering rack, the audi's also have a centre mount rack, so does a citreon saxo and also the 90's vauxhalls astra cavalier etc thats what i've got on the split just cut vauxhall steering arms at about 6" had them re-threaded to match the standard hollow split van steering arms and bobs you uncle!!!! Grin
Bugsy_malone 666
PostPosted: Wed May 12, 2010 9:07 pm    Post subject: Reply with quote
Well been looking at this steering rack option a little more.
Looked at saxo and audi racks (as the earlier polo ones dont seem common on ebay) and I can kind of see how they are done, however theres a bit of a sticking point which the layout of the racks.
Basically the tierods sit infront of the rack which is there the beam is! Now I have looked a little at pictures of the different racks and I can see that the end unbolts and will bolt on 180degrees round, however that still puts it in an odd place so I think I need to do a bit more research as space is really limited under a beetle fuel tank.
What I have been looking at though is different tierod ends, as it seems if I was to re engineer an audi centre steer (as VAG are my prefered choice) then I would need some ends, which meant by accident I stumbled on the stock tie rods that screw into the likes of my polo mk4 rack. What I found was is that the audi A4 seems to have the little mushroom joint that screws into the end of the rack, its then just theaded meaning you can screw what you like on there! Seems A4 racks also have really dinky tierods with quite a lot of travel!
as seen here
I was wondering if the inner rod end is the same for most racks, if it is the case I could get audi inners and then the rest is a piece of cake! I could then get threaded hex bar and make any length I want!
Superleggo
PostPosted: Thu Jul 01, 2010 8:59 pm    Post subject: shortening racks Reply with quote
The stock car boys have been shortening rack for years. most use the moris minor rack beacuae it is very strong and easy to adjust in length. It takes the crashes in to the side wall better than most. As these are now becomming harder to find people are also using the Escort rack. When adjusting the rack length it is important to make sure that all the ball joints align or you will have serious bump steer problems. I guess you could also do this on a power rack but I am going down the route of morris minor rack and Corsa electric column on my other project car as it is easy to adjest the length of the rack and the Corsa system is easy to adjust for sensitivity to give a nice feel. I think there is a post somewhere on this forum using a Rascal rack and a Corsa column which seems a good choice for the bus set up.
Bugsy_malone 666
PostPosted: Thu Jul 01, 2010 9:06 pm    Post subject: Reply with quote
well since I started this thread I have since managed to get hold of a mk2 polo breadvan rack which is the central mount one, appears its a fairly popular choice for a conversion and there is even a german company that sell a kit with the rack.
so now I just need to finish putting my beam back together and using 1 polo and 1 1302s tie rod (with polo inners and beetle outers) I should just have to make only 1 or 2 brackets Happy
