Type 3 Conversion
Terry
PostPosted: Tue May 04, 2010 3:59 pm    Post subject: Type 3 Conversion Reply with quote
I have a 69 sqback that I would like to put a Subaru motor in, has anyone had any experience with this that could offer some advice.
Thanks, Terry
famous phil
PostPosted: Wed May 05, 2010 10:10 pm    Post subject: Reply with quote
Welcome ,
I've not personally but have seen one on the net ,
Might help if you could add which engine you were thinking of , or were you kind of wanting information before purchasing an engine
PostPosted: Thu May 06, 2010 10:02 am    Post subject: Reply with quote
Watcha
I think there's a couple of guys on Aussies who've done them.
ISTR that the engine sits very high and you have to raise the boot floor to accomodate
PostPosted: Fri May 07, 2010 7:05 am    Post subject: Reply with quote
It's pretty easy to fit a water cooled motor into a type three. Plenty of room in the spare wheel well for a radiator, the engine bay is mahosive and can easily fit a quad cam Subaru motor in it with no cutting of the car, slightly different tal if you go for a turbo lump but only slightly. With enough effort you can run your coolant lines through the gearbox tunnel or you can run them beneath the car.
Is your squareback a pan scrapper slammed to the road? If so then I'd reconsider going for the Subaru motor. As mentioned above the subaru is a tall engine from the engine sump to the top of inlet manifold. If you fit the engine low enough to fit below your stock engine hatch you'll need to lift the back of the car a far bit to gain some clearance for the sump. But if you leave the chassis on the floor and raise the engine and gearbox to clear you'll be stressing cv joints and forcing the gearbox oil into the nose end and starving the diff of oil.
As above Aussieveedubbers is the best place for squareback conversions that I'm aware of. Few other places for notch and fastback conversions.
PostPosted: Fri May 07, 2010 9:05 am    Post subject: Reply with quote
PostPosted: Sat May 08, 2010 12:50 am    Post subject: Reply with quote
Kai,
What beer/drugs are you on dude Wink
2 hrs between posts (the same post)
Do we have a "stasis leak"?
No, I'm not messin'/
hansend23
PostPosted: Sat May 08, 2010 1:54 am    Post subject: Reply with quote
clay just put one in his fasty.that kid did it in two weeks.i was impressed.
he hit the pan,and now is shortening it.
just do it!
PostPosted: Sat May 08, 2010 1:55 am    Post subject: Reply with quote
Grab some shots please Happy
How's your bug doing?
PostPosted: Sat May 08, 2010 6:28 am    Post subject: Reply with quote
ElusiveStranger wrote:
Kai,
Nope I've not a clue what's happened there then.
Can't blame drugs officer ES..... I've been clean since the second night of bug jam 2002. I've choosen to forget the details.
Must be my evil twin brother and his hot tub time machine playin silly buggers.
