Auto Initiate Jedi
Posted: Sat Apr 17, 2010 8:43 am Post subject: FAULT 32 ? |
Hi does any one know what fault 32 is on the subaru fault list?
i keep getting this red light on the dash fault led just now and then
it seems to be since i have had an lpg conversion but when turn the
engine off and then back on again it has gone out so i plugged the
black fault plugs together the other day and it had 3 slow flashes
followed by 2 fast ones fault 32 i think, any help would be most appreciated as im stuck now and dont want to drive it until i know
what this fault is
cheers phil |
Bigbadbugga Jedi Knight
Joined: 25 Jan 2009 Posts: 160 Location: nr Liverpool, uk
Posted: Sat Apr 17, 2010 1:59 pm Post subject: |
32 is 'oxygen sensor or circuit'
check the wiring, remove the sensor and blow out any crud.
if it still throws up the code replace the lambda sensor.
to reset codes plug both green and black together and start the engine, _________________ Located near Liverpool.
Building a full custom 1972 Beetle with an EJ25 (n/a sohc),Porsche 944 IRS conversion and Rjes bellhousing. |
Posted: Sat Apr 17, 2010 2:02 pm Post subject: |
Here are all the codes with instructions on the legacy forums.
http://www.uklegacy.com/forums/index.php?showtopic=94611 _________________ Located near Liverpool.
Auto Initiate Jedi
Posted: Sat Apr 17, 2010 7:19 pm Post subject: |
Thanks for the info i checked the lpg wiring were it taps in to the lambda sensor and found this there was only 2 strands of wire still connected to the sensor the fitter had nearly cut through the lot bearing the wire, what a bodge it was a real pain to fix as it was so close to the plug, i dont want to call any one but i paid good money to a well known fitter, i just hope i have fixed it now
Thanks for the info again
cheers phil |
