Hi I have in my hands wiring loom from rjes now I need to know about how to connect the start solenoid from the Ignition Swiss?
The Instructions tel me there are yellow/blue wire how goes to the start solenoid spade terminal. Do I have to use the wire how are already in the car from the ignition sw or do the start go Thur the ECU?
Posted: Tue Apr 27, 2010 10:26 am Post subject:
Sorry about the delay replying. Most Subaru starter motor solenoids have one 1/4" spade terminal. This is what the cold start / starter solenoid wire from the Subaru harness needs to connect to, as well as the thick VW 'start' wire fron the ignition switch. Some starters have multiple spade terminals connected together, which makes it very easy, but the wire on any harness I have converted will have a 'piggyback' connecor to allow both wires to be connected on a starter with only one 1/4" terminal. I hope that helps. _________________ Regards,
