95 EJ20T coolant circuit design and what header tank???
Goto page Previous  1, 2
PostPosted: Fri Nov 13, 2009 4:31 pm    Post subject: Reply with quote
MostlyMonki wrote:
erm, no extra header tank... just extra fittings on the one header tank (with an expansion bottle - as per subaru).
I realise that, I guess I sounded right in my head when I wrote this out.
Looking at the RJES coolant diagram where Rich has taken the feed for the T25 header, you've taken the same feeds/locations and feed the subaru header tank.... instead of the T25 cause you haven't got one Wink
you've been a massive help and I owe you a beer.
Very very grateful.
MostlyMonki
PostPosted: Sat Nov 14, 2009 12:59 pm    Post subject: Reply with quote
sounds about right. I'll still try and knock up a diagram over the weekend... but its pissing down now.
heres a couple of photos i have from when i did mine:
modified header -
rad bleed hose -
pipe going to top of coolant mani -
engine "bay" -
hope that helps....
PostPosted: Thu Nov 19, 2009 10:38 am    Post subject: Reply with quote
B4Tfink wrote:
No17 is the top up bottle behind the no plate of a t25...
sorry thats all i can help with ..
I see youre in in the ghetto if you wanted to see a n/a t25 rjes conv (not sure if it would help or not?) in the flesh i work in farnham just give me the nod Wink
pm sent
PostPosted: Sun Jan 17, 2010 9:21 pm    Post subject: Reply with quote
So I've been chatting to a couple of the known experts on this matter and I've opted to adapt my own kinda design for the coolant system going from what I have learnt from this forum.
So I ve choosen to go with a Vauxhall frontera header tank, I ran a 8mm bleed line from the radiator to the header tank, and for the turbo return line I did away with the Subaru header tank all together and basically joined the top hose connection to the bottom hose connections from the subaru header tank.
Pictures I hear you cry-
Turbo return outlet
I've taken to here-
Ive taken the bottom header outlet
to here-
The top header connection
I've taken to here-
The little bleed for the radiator-
Is connected to the subaru radiator here via a 8 mm tube I've ran the length of the car.
I hope this works Grin
PostPosted: Tue Jan 19, 2010 11:08 pm    Post subject: Reply with quote
Oooops, the bottom of the header should go to your stat line.
Your engine manifold pipe (your welded on bit) should go to the top of the tank.
You have your connections the wrong way around
The reason.... water/air/vapour flows into the top of the tank, the water falls to the bottom and out, the vapour remains. When the system pressurises the vapour/air exits via the cap.
I run my tank about 1" shy of the centre flange when cold.
I can't comment on the turbo pipes as I haven't got a clue
PostPosted: Wed Jan 20, 2010 7:37 am    Post subject: Reply with quote
Elusive your correct, well spotted.
I've cocked up the post though and posted the pictures the wrong way round. I have infact done it as you've stated. I've now edited the previous post now so they are the correct way round.
It would have been sweet if they where the other way round as my hose connections are both different sizes at each end when connected. My hose connections are 15mm at one end and 20 at the other for both the top and hoses connecting the tank. I've had to be cunning to get them to fit correctly. I've even used the vauxhall hoses that came with the tank which made it very easy to fit the tank.
As for the turbo-
I''m confident that this will work but if it doesn't then I'll have to include the turbo return in with the header tank with a T piece in my top expansion tank and I'll then block the original turbo return which is already connected to the stat line.
Or
come up with something else lol
PostPosted: Thu Jan 21, 2010 8:18 pm    Post subject: Reply with quote
oooppps glad i just read that before i fill up!!!!!!!!!!
i did the bottom of the header to manifold jobbie....
..cheers guys
PostPosted: Thu Jan 21, 2010 8:20 pm    Post subject: Reply with quote
hehe
PostPosted: Sun Jan 24, 2010 8:04 pm    Post subject: Reply with quote
... ok i'm an idiot......
I managed to mangle up the hard pipe that leads to the stat housing some time ago ( it all came flashing back today when i went to change the bottom header pipe )..
Does this pipe also have a feed to the isv??? and then to which opening on the stat, top or bottom... cos ive taken that pipe away aswell
cheers
PostPosted: Sun Jan 24, 2010 8:49 pm    Post subject: Reply with quote
The black state line is the return from the ISV, you are correct.
It's fed coolant from the coolant manifold.
Page 2 of 2
