OBD1 Diagnostics...... How?
currylager
PostPosted: Sat Jan 16, 2010 7:10 pm    Post subject: OBD1 Diagnostics...... How? Reply with quote
Ok once i get the brake disc conversion kit bolted on my 2.2 legacy bus i want to focus on diagnosing the lit fault bulb on the ECU, the bus runs well and will pull 90mph easily with more to go Wink . But i would like to be able to iron out any problems.faults with the ECU before the camping season starts . Lots of OBD2 stuff for sale on Ebay but no OBD1 Sad . So where do i go from here?
Thanks in advance,
James
HMMM, dont know yet, but i'll have a go!!!!
PostPosted: Sun Jan 17, 2010 4:48 am    Post subject: Reply with quote
Plug the black, single pin error code read connectors together, turn the ignition on (but don't start the engine), and decipher the morse code type 2 digit error coder (dashes = tens, dots = units). No equipment needed. You can get more info out with diagnostic gear, but it's rarely necessary.
currylager
PostPosted: Sun Jan 17, 2010 6:36 pm    Post subject: Reply with quote
Thanks for the reply. Are the error code connectors part of the original loom?. If so i may need to use the pinout to locate the wires due to the loom being modified?. And where is the fault code indicator indicator located, or is this actually the fault indicator lamp that i need to be reading?. Sorry if i'm being a bit thick
PostPosted: Tue Jan 19, 2010 10:55 pm    Post subject: Reply with quote
Yes they are. You'll see them located on the wiring diagrams. IIRC they also go to the Subaru "Select Monitor" plug
It won't be too dificult if you can read a diagram. You could always remake the connections at the ECU
All dependant on years. Early ones were actually on the ECU. Later cars had the bulb in the dash. Just supply the lamp with 12V as the ECU takes the other side to ground. If you use a 12V LED remember "Long leg, red"
[b]You're fine, it's a bit of a mare! [b]
currylager
PostPosted: Wed Jan 20, 2010 7:20 pm    Post subject: Reply with quote
Cheers Elusive Wink . Will get going on this one when the weather improves. The donor car was a 92 Legacy which had the ECU fault lamp on the instrument pod, so i'll try reading that Wink . Just need a table for the codes Eeeek
PostPosted: Wed Jan 20, 2010 8:27 pm    Post subject: Reply with quote
Take a gander at Brent's site (he posts on here occasionally)
http://www.weidefamily.net/vanagon/
Click "Suby-engine 1" then go to the tabs below, click "Wiring" and near the bottom's a file called "Idiots Guide to Subaru EJ ECU Codes"
Then read the one under that "Subaru ECU Trouble Codes"
Brent's site is ace!
(Blimey, he's done a fair bit more since I last looked)
currylager
PostPosted: Sat Jan 23, 2010 8:25 pm    Post subject: Reply with quote
Cheers, van is now running and able to stop a bit better with front discs Grin . Will be moving onto ECU probs next week, so thanks
