A few pug conversion questions
Zebedee
PostPosted: Sat Dec 26, 2009 12:01 pm    Post subject: A few pug conversion questions Reply with quote
Looking at getting a petrol T25 and fitting a pug 1.9 to it but i've got a couple of questions.
I've seen a few pug 1.9td lumps in scrappies with either the lucas or bosch fuel pumps on them but which is best?
Is the bosch one more tunable?
Is it true you can't run the lucas one on veg oil?
Also, how easy is it to connect the water hoses from the engine to the existing water pipes in a T25?
Is there a certain model to get suitable hoses from or do you just use universal hose?
PostPosted: Sun Dec 27, 2009 11:18 pm    Post subject: Reply with quote
Not to hot on pug stuff but do know Lucas and veg oil don't mix so def go with Bosch pumped engine if looking to run on veg oil
Zebedee
PostPosted: Mon Dec 28, 2009 10:45 am    Post subject: Reply with quote
Cheers. Bosch it is then.
illzlee
PostPosted: Tue Dec 29, 2009 12:45 pm    Post subject: Reply with quote
yep, jp is right the Bosch pump is more tunable and will run on veg oil. The lucas one ain't happy about either!
'79 Bay running citroen 1.9td and phat tyres!
