newbie help - ecu pinout/crank sensor
gdr
PostPosted: Wed Dec 02, 2009 4:08 pm    Post subject: newbie help - ecu pinout/crank sensor Reply with quote
Hello everyone, I am trying to put a Subaru conversion into a Bay window camper and was going ok, until now that is and I have to attempt the wiring I am now just going round in circles getting even more confused
I have a EJ22 engine and a wiring loom form a 1.8 and a ecu that looks different to others i have seen its a Hitachi, and I am in need of a pinout diagram and I cant seem to find one anywhere does anyone know where I can get one.
The second question is the crankshaft sensor that I have only has two wires coming from the loom and the Subaru garage keep trying to sell me one with a three wire connection, has anyone else come across this problem or found any solutions
Thanks in advance for any help/advice you may have
Gavin
PostPosted: Wed Dec 02, 2009 8:00 pm    Post subject: Reply with quote
EJ22 Engine (year?)
EJ18 Loom (year?)
What's the ECU from?
Being such a mismatch, did you hear it running before you bought it?
Sounds like a 'mare to me
I know EJ20s have a 2 pin Crank/Cam sensor, along with the few EJ22s I have seen.
Sure he wasn't trying to sell you an O2 sensor?
gdr
PostPosted: Wed Dec 02, 2009 8:16 pm    Post subject: Reply with quote
the engine is a 1994 (bought it ready for a conversion e.g adapter plate wiring loom etc, but when looked at the loom we realized it had been butchered) So I went to my local scrappys and got a wiring loom out of a 1.8 1995, we took the complete loom, inlet manifold and ecu (the sensor was missing though)
As for the Subaru garage we only have one near by and the guy was adamant and a bit of an arse
help
MostlyMonki
PostPosted: Thu Dec 03, 2009 12:18 pm    Post subject: Reply with quote
sounds like a nightmare mate, I've only done stuff with ej20's... but are the 1.8 and 2.2 looms even the same? if i were you I'd bite the bullit and get a loom and ecu that you know came out of a 2.2 of the same year(ish). youll be chasing your tale for ages otherwise...
