What is the best gearbox solution?
Goto page 1, 2, 3, 4, 5, 6  Next
Superleggo
PostPosted: Thu Nov 12, 2009 11:25 pm    Post subject: What is the best gearbox solution? Reply with quote
Hi folks - I have just joined the world of classic vw'sbut have had a modern Passat for the last 8 years. Having just finished welding up my 1971 Bay and I am trying to decide what to do next. I plan to end up with a usable classic with classic looks but something that will keep up with modern traffic. I was thinking that 150 -200 HP would do nicely in a camper so there are lots of engine options. To me the biggest problem is the gearbox as the ratios seem a bit lame. I would like a van that will cruise at 80-85mph and return good mpg like my Passat . I know the Bay is a bit of an aerodynamic brick but every white van on the road can do 90mph if not they would not sell and they even return sensible mpg. Can a Bay do the same? Having read many of the posts on the forum I suppose the obvious choice is 091 box and Subaru engine.
However I was thinking why not use a transverse engine / box in the back. I realise that most combinations will not fit sensibly as the engine will end up in the load bay or I will end up with 5/6 reverse gears and one forward. But why not fit a Honda/VW combination. The Honda engine runs backwards so it be possible to mate one of the Honda engine to a VW or other gearbox or visa versa. Will any of the gearboxes be happy running backwards? Has anybody done it? any thoughts?
VW Camper 1971
VW Passat 2006
Lotus Elan +2 1968
Mini Moke 1974
Land Rover Series 2a 1967
DB5 replica Work in progress
Another day another car!
RobScott
PostPosted: Thu Nov 12, 2009 11:58 pm    Post subject: Reply with quote
hmm, well the engine will still be basically mid mounted what ever transverse box you use. seems a tough way of doing somthing that can be done a lot simpler.
at the end of the day a bay is old technology, if you want to be blasting down the motorway at 80-85 mph in a bay then you will need some decent suspension and brakes, modern vans are just that... modern.
you will end up hacking a lot out of your camper if you go down that route, maybe go for a built box with bigger ratios? also think about trying to sell the camper in the future, no one will want a hacked up bay with a random engine/box combination.
PostPosted: Fri Nov 13, 2009 9:38 am    Post subject: Reply with quote
i understand what you are thinking - i too want to cruise at sensible speeds ....having spent a lot of time and even more money fitting my subaru turbo to my van on a modifie 091 box and RJES bell housing it is ulitmatly still going to be compromised by the gearbox.
Had I known better at the time I could have saved a fortune by using the subaru box(admittedly they arent exactly brilliant) but are 5 speed, modern and cheap ( i could buy 4 of them for the cost of one of my 091s). The other advantage is you use all subaru components- clutch etc etc. Yes it would be a lot of fabircation but in my case (turbo) I have spent a lot of time fabricating stuff anyway. i still have moments of thinking im going to cut it all out and start again but i will see how it all drives if i ever finish it!!!
So I would definatly be looking to either mdmount the engine and reformat the rear end or if i was a` diesel enthusiast i would be looking at fitting a transverse set up....like a nice 150bhp VAG Tdi and 6 speed box.
PostPosted: Fri Nov 13, 2009 10:34 am    Post subject: Reply with quote
EG...
GTTDI 150 with 6 speed.
PostPosted: Fri Nov 13, 2009 12:37 pm    Post subject: Reply with quote
I've seen this done before, but I can't remember for the life of me where I saw it.
Was a Bay window and a Subaru engine gearbox including front suspension, the guy was in belgium but he sold it after finishing it.. Why do people do that by the way.
PostPosted: Fri Nov 13, 2009 1:08 pm    Post subject: Reply with quote
That'll be this one..
http://vwkd.co.uk/bb/viewtopic.php?t=1501
http://vwkd.co.uk/bb/viewtopic.php?t=38
http://vwkd.co.uk/bb/viewtopic.php?t=1962
PostPosted: Fri Nov 13, 2009 1:32 pm    Post subject: Reply with quote
next year bears have a proper 5 speed busbox coming out
PostPosted: Fri Nov 13, 2009 1:42 pm    Post subject: Reply with quote
@ a price though think he said £3.5k Eeeek should be a awesome box though and weighed up next to a porsche box and what's involved with making them fit prob not a bad investment Cool
PostPosted: Fri Nov 13, 2009 3:32 pm    Post subject: Reply with quote
he should do some cunning marketting and team up with RJES and offer them ready converted of the shelf at a slightly cheaper price than the two parts bought seperatly. THen its a ready made package for conversions off the shelf.
PostPosted: Fri Nov 13, 2009 3:58 pm    Post subject: Reply with quote
Thats the one, should of know it was on ere
Superleggo
PostPosted: Fri Nov 13, 2009 5:24 pm    Post subject: Thanks for the quick reply Reply with quote
wow - you guys are on the case. Thanks for replying so quickly. i have spend ages reading some of your posts and they have provided great inspiration to me and persauded me to join in. I have very much enjoyed reading Richbaker78 build - stunning work and thanks for such an honest reply. I am keen noot to loose space inside the van and hence I had already dismissed Ford option and any other FWD mover to mid engine layout. I really think that RWD rear engine mounted transversly would work well. I can't see why a modern transverse box will not run backwards if mated to a Honda engine, or a Honda box running backwards to any engine of your choice. Surely it would make a very drivable bus. Someone must have tried it?
The Subaru to 5 speed box is stunning but too much space lost sadly. I bought the bus to go camping in but was hoping not to spend all the holday getting there! hence the need for a different engine / box combination. I am not frightened of fabrication as I scratch built the body shell chassis and suspension for my DB5 replica.
VW Camper 1971
VW Passat 2006
Lotus Elan +2 1968
Mini Moke 1974
PostPosted: Fri Nov 13, 2009 6:17 pm    Post subject: Reply with quote
jp wrote:
EG...
i like that! is that a van of the forum?
Page 1 of 6
