15 window delux...G50 and scooby turbo conversion......
Goto page Previous  1, 2, 3, 4
65deluxe
PostPosted: Mon Jun 15, 2009 7:42 am    Post subject: Reply with quote
Someone had a busy weekend then - Deva Dubs and Rods for me - good show .
Trying to finish a bay window and do work on samba so slow progress on both !!!!
Need to pull my finger out !!
" If its got wheels or tits its gunna cost you money "
"whatever you build if its low and on earlies you wont go wrong "
15 window delux
PostPosted: Thu Jun 18, 2009 9:11 pm    Post subject: Reply with quote
managed to get 3 hours tonight after work and shes getting there...slowly....
got the outer sill and sill strengthener welded together...opted to seam weld rather than plug weld because of the power that will be going through her...cant afford any broken welds...
probably the wrong way of doing it but seeing as i need and have ordered a short sill repair and a b post repair i put the outer sill on so i know where it should sit....
next came the other chassis centre......
well the old one out....
its amazing that this was 'new' but behind it was a dirty big hole!!! so i welded it up
Then after fixing this in went the new one...
well thats all till the next time i get a chance...
15 window delux
PostPosted: Fri Jun 19, 2009 7:45 pm    Post subject: Reply with quote
right.....had a couple of hours again.....
out with the old rusty out rigger,.....
and again some crusty bits behind it....
in with the new.....
15 window delux
PostPosted: Fri Jun 19, 2009 7:47 pm    Post subject: Reply with quote
next the front.....
and amazing the first one with no crust behind it....
and the new one goes in.....
then an attempt on the front top hat before i run out of time...i will finish cutting this out tomorrow.....
65deluxe
PostPosted: Wed Aug 12, 2009 9:41 pm    Post subject: Reply with quote
Hi Fella - any update on your build !!
15 window delux
PostPosted: Mon Aug 17, 2009 9:09 pm    Post subject: Reply with quote
hi....yes been a bit busy doing a fishing boat so havent had much time....will post some new pics asap
hansend23
PostPosted: Tue Aug 18, 2009 5:13 am    Post subject: Reply with quote
would love to see your progress also
just do it!
Page 4 of 4
