oildraggon6 Wannabe
Posted: Thu Jul 16, 2009 11:33 pm Post subject: cooling issue |
so i was driving sixty and my cooling system stopped working..... i hosed out all the lines and put another pump in still nothing any help _________________ once you go subaru you never go back |
Posted: Fri Jul 17, 2009 10:57 am Post subject: |
er - could be anything.....
bit more info would help such as car/ engine/ set up of system / parts used etc etc |
Bigbadbugga Jedi Knight
Joined: 25 Jan 2009 Posts: 160 Location: nr Liverpool, uk
Posted: Fri Jul 17, 2009 12:01 pm Post subject: |
Stopped working?
as in 'overheated'?
as rich says, we would need much more info to be able to help _________________ Located near Liverpool.
Building a full custom 1972 Beetle with an EJ25 (n/a sohc),Porsche 944 IRS conversion and Rjes bellhousing. |
oildraggon6 Wannabe
Posted: Fri Jul 17, 2009 11:43 pm Post subject: |
oh yeah geez sorry..well its a ej22 in a bug with the rad up front and i don't run a stat i switched out the water pump and it still is not pumping... _________________ once you go subaru you never go back |
MostlyMonki Jedi Master
Posted: Sat Jul 18, 2009 12:13 pm Post subject: |
sounds exactly the same as mine was. it'll probably be an air lock, as theyre a real barsteward to blead. take off the hose that goes to the stat, shove a hosepipe up it til it gets to the radiator and flush the system through for about 5 minutes with the top off the reservoir.
how have you rigged up your heater pipes? they need to flow so if you havent got a heater just loop them, then stick the stat back in. _________________ '72 Ratty Bug - Subaru EJ20 Turbo motor. |
Joel Jedi Master
Posted: Sun Jul 19, 2009 12:27 pm Post subject: |
you cant run these engines without a thermostat
the computer uses the coolant temp to control the fuel mixture
with no stat and a huge cooling system like in abug it would never be getting up to temp
so the computer would be running a richer mixture most of the time
be like driving around with the choke on all day
my bet is heater loop not connected or air locks _________________ 1974 1303 Germanlook Suba-Beetle
hansend23 Jedi Master
Joined: 04 Mar 2009 Posts: 333 Location: Washington state
Posted: Mon Jul 20, 2009 1:39 am Post subject: |
it was an airlock...he called. _________________ just do it! |
