col Wannabe
Posted: Fri Jul 17, 2009 1:17 pm Post subject: Why wont it idle? |
After such a long time i have managed to get the engine in and most thing sorted but the engine does not seem to want to idle. It seems very happy at high revs but after turning it on it will only idle for a few seconds and then cuts out.
Any ideas any one?? |
hansend23 Jedi Master
Joined: 04 Mar 2009 Posts: 333 Location: Washington state
Posted: Fri Jul 17, 2009 7:01 pm Post subject: |
no air leaks after the maf?
hmm,iac valve? _________________ just do it! |
MostlyMonki Jedi Master
Posted: Fri Jul 17, 2009 9:08 pm Post subject: |
yeah maf would be my first guess. how about a bit more info on engine type etc? ej20? turbo? it'd help... _________________ '72 Ratty Bug - Subaru EJ20 Turbo motor. |
col Wannabe
Posted: Sat Jul 18, 2009 8:17 am Post subject: |
| sorry its a 2l from a 1997 legacy non turbo. I'll check the maf and make sure there are no leaks. hope that sorts it out |
Posted: Sat Jul 18, 2009 12:06 pm Post subject: |
got a check engine light rigged up? if so it'll throw a code for the maf if theres a leak problem. _________________ '72 Ratty Bug - Subaru EJ20 Turbo motor. |
col Wannabe
Posted: Sat Jul 18, 2009 2:02 pm Post subject: |
hi, thanks for the tips - i checked everything was done up tight and there must've been an air leak somewhere as now it seems to be running much better. still some tweaking to do to get it just right. i'll check the fault light next.
Fingers crossed for an MOT soon on it  |
Posted: Sun Jul 19, 2009 9:59 pm Post subject: |
if you had an airleak it will throw a maf code - so dont replace the maf right away, just reset the ecu then check for codes after another test-run. _________________ '72 Ratty Bug - Subaru EJ20 Turbo motor. |
