cooling issue
oildraggon6
PostPosted: Thu Jul 16, 2009 11:33 pm    Post subject: cooling issue Reply with quote
so i was driving sixty and my cooling system stopped working..... i hosed out all the lines and put another pump in still nothing any help
once you go subaru you never go back
PostPosted: Fri Jul 17, 2009 10:57 am    Post subject: Reply with quote
er - could be anything.....
bit more info would help such as car/ engine/ set up of system / parts used etc etc
Bigbadbugga
PostPosted: Fri Jul 17, 2009 12:01 pm    Post subject: Reply with quote
Stopped working?
as in 'overheated'?
as rich says, we would need much more info to be able to help
Located near Liverpool.
oildraggon6
PostPosted: Fri Jul 17, 2009 11:43 pm    Post subject: Reply with quote
oh yeah geez sorry..well its a ej22 in a bug with the rad up front and i don't run a stat i switched out the water pump and it still is not pumping...
MostlyMonki
PostPosted: Sat Jul 18, 2009 12:13 pm    Post subject: Reply with quote
sounds exactly the same as mine was. it'll probably be an air lock, as theyre a real barsteward to blead. take off the hose that goes to the stat, shove a hosepipe up it til it gets to the radiator and flush the system through for about 5 minutes with the top off the reservoir.
how have you rigged up your heater pipes? they need to flow so if you havent got a heater just loop them, then stick the stat back in.
Joel
PostPosted: Sun Jul 19, 2009 12:27 pm    Post subject: Reply with quote
you cant run these engines without a thermostat
the computer uses the coolant temp to control the fuel mixture
with no stat and a huge cooling system like in abug it would never be getting up to temp
so the computer would be running a richer mixture most of the time
be like driving around with the choke on all day
my bet is heater loop not connected or air locks
hansend23
PostPosted: Mon Jul 20, 2009 1:39 am    Post subject: Reply with quote
it was an airlock...he called.
just do it!
