BlackCosmos Padawan
Posted: Tue Jun 30, 2009 7:55 am Post subject: Fuel Pumps.. |
| been having sum issues with the external fuel pump im running on me t25 with wrx fitted..wots the best pump suited or is it best to find sum one to mod tank to take subaru in tank pump?? thanks.. |
MostlyMonki Jedi Master
Posted: Tue Jun 30, 2009 8:45 am Post subject: |
I've got a sytec motorsport 5 bar pump on my wrx bug.
what pump you running? and whats the problem? _________________ '72 Ratty Bug - Subaru EJ20 Turbo motor. |
BlackCosmos Padawan
Posted: Tue Jun 30, 2009 12:56 pm Post subject: |
| a cossy pump,meant to be 6bar..when started the fuel pump relay clicks and interfers with the fuel pump..seems to improve when hot..had electrics checked been given the all clear on them..may have to get subaru diagnostics done..have put new fuel tank and pump on and checked maf..any ideas?? |
Posted: Tue Jun 30, 2009 1:03 pm Post subject: |
do you mean that when its running the relay intermitantly clicks (i.e. not just once when you start it)? if so sounds more like a relay problem than a pump thing...
can you give any more details (step by step styliee)? _________________ '72 Ratty Bug - Subaru EJ20 Turbo motor. |
BlackCosmos Padawan
Posted: Tue Jun 30, 2009 2:09 pm Post subject: |
| when running the relay clicks intermittently,think its the feed to the pump being interferred with..even if i by pass relay it still gets problems on tick over/or driven..seems to improve when the engines hot..have changed relay,fuel tank and pump..had electrics checked theyre ok too..was ok just started out the blue?? |
potholebill Force Sensitive
Posted: Tue Jun 30, 2009 7:38 pm Post subject: |
| Defo sounds electrical, have you checked the ground connection to the relay, vibration maybe causing it to come loose and click off and on. |
Posted: Tue Jun 30, 2009 7:58 pm Post subject: |
the earth or the relay goes back to the ecu iirc.... the earth on the pump might be worth a look though. whats it like if you just leave it idling after starting without driving? same thing happening? _________________ '72 Ratty Bug - Subaru EJ20 Turbo motor. |
Posted: Tue Jun 30, 2009 9:02 pm Post subject: |
| MostlyMonki wrote: | | the earth or the relay goes back to the ecu iirc.... the earth on the pump might be worth a look though |
Correct, the ECU always grounds the "whatever" on the other end.
So check the 12V supplied to the relay and pump along with the ECU ground connection & of course the pump ground. _________________ The advice you receive on here is worth the paper it's written on.
BlackCosmos Padawan
Posted: Wed Jul 01, 2009 8:29 am Post subject: |
| had the electrics checked yesterday and beenn given the all clear,no earth faults etc..probably gonna have subaru diagnostics.. |
Posted: Wed Jul 01, 2009 9:30 am Post subject: |
| BlackCosmos wrote: | | had the electrics checked yesterday and beenn given the all clear,no earth faults etc..probably gonna have subaru diagnostics.. |
yeah but where the electrics checked while the car was actually moving? if its a fault caused by vibration youd be none the wizer.
what years the engine? if its pre 97 then subaru diagnostics via the ecu will just check the fault codes in exactly the same manner that you could do yourself with the check-engine light.... and i'd be amazed if they pick up on any electrical fault not caused by a faulty sensor.
might be worth checking the pump itself by hooking up a wire directly from the battery + to the pump +, and battery - to pump -, then see if it runs without interruption.... if it does then you've deffinately got a loose wire/dodgy relay somewhere. _________________ '72 Ratty Bug - Subaru EJ20 Turbo motor. |
BlackCosmos Padawan
Posted: Wed Jul 01, 2009 12:55 pm Post subject: |
| have bypassed relay so fuel pump ran constant and still had the problem..it does improve once the engines at operating temp..becomes drivable.. |
BlackCosmos Padawan
Posted: Mon Jul 06, 2009 7:58 am Post subject: |
| have checked relays,its not that..definately seems to improve when engines hot..clicks fuel pump relay consistently when cold..any ideas?? |
