Griff71 Jedi Knight
Posted: Fri Jun 26, 2009 8:16 pm Post subject: Engine removal!!!! |
Trying to remove the subaru motor from my t25. Sure i have removed all bolts and disconnected water lines that would hold in place or restrict. However i can not get the motor to budge only a few mm at most. I have anothee pair of hands to help but even still cannot get it out. Have tried putting in gear and rocking but no joy. Anything obvious i have missed?
Urgent advise needed as i need motor out tonight.
Thanks
Griff |
Bigbadbugga Jedi Knight
Joined: 25 Jan 2009 Posts: 160 Location: nr Liverpool, uk
Posted: Fri Jun 26, 2009 10:56 pm Post subject: |
is it a turbo motor?
I heared there is something you need to do to disconnect the turbo clutch.
I'm sure someone will be along who can give you more details. _________________ Located near Liverpool.
Building a full custom 1972 Beetle with an EJ25 (n/a sohc),Porsche 944 IRS conversion and Rjes bellhousing. |
Posted: Fri Jun 26, 2009 11:48 pm Post subject: |
Might be the location pins being stubborn if it's not a turbo motor.
If it's not a specific RJES problem you're better posting to "Subaru Power"  _________________ The advice you receive on here is worth the paper it's written on.
doppelganger Jedi Guardian
Posted: Sat Jun 27, 2009 8:00 am Post subject: |
sounds like we will find its a turbo or the stubborn pin ,i cant think of anything else  _________________ vwdrc class rep
wackos00 Padawan
Posted: Wed Jul 01, 2009 11:16 am Post subject: |
| 2 things I have learn't the gearbox and engine have to be perfectly aligned while supported otherwise everything is obber tight, also sometimes things need a bit more brute force! |
