vss sensor calibrator
johan84
PostPosted: Wed Jun 24, 2009 6:13 am    Post subject: vss sensor calibrator Reply with quote
hello
ihave bought a jdm sti v7 form 2002
with ecu and wiring loom
and i need i thinks de VSS sensor to get the engine running good
but i have G50 transmission do i need the orginal piorsche speed sensor and connect dis to the wiring loom
or do i have to get the subaru vss to my g50 gearbox
and how about the calibrator is it just put in between it?
how is it working?
greetings johan
PostPosted: Wed Jun 24, 2009 8:48 am    Post subject: Reply with quote
Welcome to the forum
So what are you putting it into?
If you're running a bay a 4 pulse per wheel revolution will give you a signal that's about 5-7% (IIRC) out.
This is fine on a 98 EJ20
johan84
PostPosted: Wed Jun 24, 2009 3:51 pm    Post subject: Reply with quote
no it is going i to a bug with a g50 transmission
i from holland so my english is not so good as you guy's
wat do you mean by 4 pulse per wheel?
and ther is only 1 vss only on tyhe gearbox is it ?
and wat means IIRC?
so i just need a converter to convert the right speed to my ecu
and can i yuse a porsche or a subaru vss ?
greetings johan
doppelganger
PostPosted: Wed Jun 24, 2009 5:22 pm    Post subject: Reply with quote
IIRC = if i recall correctly Wink
vwdrc class rep
PostPosted: Wed Jun 24, 2009 7:55 pm    Post subject: Reply with quote
4 pulse per wheel revolution - the VSS sends out 4 signals to the ECU for every wheel revolution
I believe later (ODBII) ECUs can be adjusted for different wheel diameters
My Vsssss thread in Fag Packet shows a Brantz VSS along with RJESs own. These will both fit onto the back of Beetle Speedos
gerrelt
PostPosted: Wed Jun 24, 2009 9:13 pm    Post subject: Reply with quote
I'll translate:
Wat hij dus zegt is:
De VSS (vehicle speed sensor = snelheids sensor) stuurt per omwenteling 4 signaaltjes naar de ECU.
Er zijn dus twee sensors (eentje van Brantz en eentje van RJES) te koop die je aan de achterkant van je km-teller kunt schroeven (tussen de kabel en de teller) zodat je daar je VSS signaal vandaan kunt pakken.
Mooi dat je je weg naar dit forum hebt gevonden.. je bent toch de Johan van de Keversite?
Zeg het maar als je meer vertaald wil hebben.
homepage
VolksRomeo 13033 S 1.4 IE
hansend23
PostPosted: Thu Jun 25, 2009 6:45 am    Post subject: Reply with quote
just learned what IIRC means,thanks
sorry off topic.
i want a vss that fits on the back of a bug speedo
ill go look...
just do it!
doppelganger
PostPosted: Thu Jun 25, 2009 10:44 am    Post subject: Reply with quote
gerrelt wrote:
I'll translate:
what does the highlighted word mean? Grin
vwdrc class rep
PostPosted: Thu Jun 25, 2009 12:41 pm    Post subject: Reply with quote
doppelganger wrote:
gerrelt wrote:
I'll translate:
Laugh Out Loud Laugh Out Loud Laugh Out Loud
gerrelt
PostPosted: Thu Jun 25, 2009 9:07 pm    Post subject: Reply with quote
Laugh Out Loud Laugh Out Loud Laugh Out Loud !!
"Kunt" means "can", like in "You can do that".
But, the funny thing is, if you remove the "n" in "kunt" you've got the dutch word for the female body part you guys are referring to... Grin Grin
homepage
PostPosted: Fri Jun 26, 2009 2:53 pm    Post subject: Reply with quote
Not that I didn't trust you but quality to see it on an online translator.. I really didn't expect other languages to have such a quality word.
Cool
Apologies for going off topic but Doppleganger's observations really did require further investigation
Grin
doppelganger
PostPosted: Fri Jun 26, 2009 4:19 pm    Post subject: Reply with quote
i try to read most posts even if in a foreign language Grin
vwdrc class rep
