my next rubber burner ida mk1 golf caddy 24v v6 4wd turbo ,,
Goto page Previous  1, 2, 3, 4, 5, 6  Next
splittyman69
PostPosted: Wed Apr 29, 2009 10:07 am    Post subject: Reply with quote
tuck a risk and bought this with removeable boss, as i thought its come from a mk1 , should be ok for the caddy(i think)
and oil cooler arrived too ,, more things to fit lol
PostPosted: Wed Apr 29, 2009 11:22 am    Post subject: Reply with quote
WOW its really coming together-cant wait to see and hear it on the road! GOod work fella-keep it! Grin
splittyman69
PostPosted: Fri May 01, 2009 7:01 pm    Post subject: Reply with quote
cheers alex , well ull know when the time comes lol
right small start on the wishbones
first some solid round bar
then cut and weld in place
and bit of black spray poped on and refit
may help a bit i supose
easy-does-it
PostPosted: Fri May 01, 2009 8:52 pm    Post subject: Reply with quote
Ahhhh now that's a cunning idea with the wishbones...like your style
'76 bay going superfly TDI
splittyman69
PostPosted: Sun May 03, 2009 6:44 pm    Post subject: Reply with quote
may help i reckon
right thought id better start on the seat frame again didnt want it ripping out of the floor so add some decent 2x2 box and rips the old seat mounts out
then made a decent strong box for the seat mount that shouldnt go any were soon ,and add some chassi strengh too ,
then add to make a few adjustments as im 6ft 5 and not a lot of room with the size of the dash in a caddy ,,
have to get more steel to finsh the other side lol
i was looking under the wear the old leaf springs used to be and the chassi and wasnt happy with it , so , it had to be ripped out ,
as ive now realiseing i need a stronger chassi
fits bang on inside the caddy chassi ,
carnt see that buggar going any were soon
splittyman69
PostPosted: Tue May 05, 2009 8:44 pm    Post subject: Reply with quote
not mutch due to coming down with the useal man flu ,,lol
so managed to finish off the welding ading more strengh to the chassi too
so decided im going to make a fuel tank on the rear as this will help with weight transfor as well/once ive finshed off the other side too
so ill not be needing a fuel flap anymore so ill weld that up as well
and nice clutch pot arrived too ,unsure if ill use it thow
splittyman69
PostPosted: Tue May 12, 2009 8:49 pm    Post subject: Reply with quote
well not too mutch to add at the moment
so steering wheel arrived and fits spot on with the electronic steering
and thought id chop the ecu loom to fit a contector to try match standalone to stock mk3 golf wireing plug and what a stressful job ,, lol mind finaly all cut ,colour colourd and wired up ready for re fitment
splittyman69
PostPosted: Wed Jun 03, 2009 9:45 am    Post subject: Reply with quote
i blow the stand alone ecu ,start of last week,with a coil back feed grrr , so , more re strip of wireing and repairing ,but after a week ,managed to refit the parts and pop a quick few map/setings to get it runing ,(stressfull with settings lol/
then thought might as well add the wideband , another headack ,because of were the exhaust is i had to make a hole back of the bulk head (2 layers of steel ) then because of the large plug , had to attempt to resolder stainless wire (nighmare /with a soldering iron lol) now sorted
(still no gauges working thow/speedo/works lol
thought id add the led for the wideband heater flashers til its ready , works a treat
short video of the ms video ,, needs more tuning ,but now main problems are sorted as well as i wire had come off in the ms contector causeing stress
View My Video
more tuning when the intercooler is piped and sorted
thought id have a hour at makeing a fuel tank ,
first lump of stainless, should add some extra weight balance too
then tryed out my plazma cutter great piece of kit
then a quick buzz around with the welder lol
filled it with water to check my welds lol (leak free left it for a hour )
top and pipes to sort 2moz
a dam oil leak too ,, another prob to be sorted
height of the caddy /it will have to do
splittyman69
PostPosted: Wed Jun 03, 2009 8:44 pm    Post subject: Reply with quote
bit of tank makeing 2day ...
more plazma cutting
quick zip around for fuel sensor
then a couple of tempory fits ,,nicely clears anti roll bar
make a few fasterners tomoz ready for fuel pipe work next
PostPosted: Wed Jun 03, 2009 9:11 pm    Post subject: Reply with quote
Is there anything you can't do !! awsome work on the tank.
What's the plan with the body work ? as is or some bling Cool
splittyman69
PostPosted: Wed Jun 03, 2009 9:51 pm    Post subject: Reply with quote
lol hi jp , couldnt see point in waiting for customs tanks to be made easyer with a bit of diy lol ,, well it fits anyway and holds a fair bit of water too ,, nice rear end weight ,,i reckon , body not mutch unit im happy how things are holding Grin
72panelvan
PostPosted: Wed Jun 03, 2009 10:07 pm    Post subject: Reply with quote
great work and pics as always!
Page 5 of 6
