removing your gear box
wackos00
PostPosted: Sat Apr 18, 2009 7:12 pm    Post subject: removing your gear box Reply with quote
anyone got any tips for removing the gear box with rjes bell from an ej22?
I have undone everything I can and have the box supported so as the weight isn't on the threaded studs / interferance fit studs. But I can not seem to get the two apart??
cheers,
Jack
PostPosted: Sun Apr 19, 2009 1:52 am    Post subject: Reply with quote
Stoopid Q time. Have you still got the box in the van?
If so there's two bolts right at the top of the bellhousing that need to come out
wackos00
PostPosted: Sun Apr 19, 2009 8:07 am    Post subject: Reply with quote
Yep the box and engine are still in the van. I have taken out the two bolts at the top, one long one that goes through the starter motor and one shorter on the other side of the engine. I have undone the two nuts on the studs at the bottom. Undone the bolts holding the gearbox mount to the chassis. Have I missed something?
Thanks, jack
wackos00
PostPosted: Sun Apr 19, 2009 4:46 pm    Post subject: Reply with quote
its all good, I got it off, just took a bit more force than I was expecting.
PostPosted: Sun Apr 19, 2009 5:15 pm    Post subject: Reply with quote
hehe. Think we've all been there.
Glad you've got it sorted
PostPosted: Sun Apr 19, 2009 8:05 pm    Post subject: Reply with quote
i was going to ask what clutch you had cos it makes a dfference Wink
PostPosted: Sun Apr 19, 2009 9:20 pm    Post subject: Reply with quote
What difference does it make? I only have the NA clutch
PostPosted: Sun Apr 19, 2009 9:31 pm    Post subject: Reply with quote
NA has a push to release and a turbo has pull to release which locks the release bearing in the pressure plate Wink
PostPosted: Sun Apr 19, 2009 9:33 pm    Post subject: Reply with quote
Ta, does that make it harder to mate/pull apart or is it the same?
PostPosted: Sun Apr 19, 2009 9:37 pm    Post subject: Reply with quote
totally different ,it has to be released or its never coming apart Grin
wackos00
PostPosted: Sat Jun 27, 2009 7:35 pm    Post subject: Reply with quote
ok I am only now fitting by gear box back in after it going to cogbox being rebuild, me half decapitaing my arm and so on. The engine is still mounted in the van, I have raised the box up, I have to two studs at the bottom lined up and engaged into the bell, drive shafts connected, but I am about 12mm from the box being home to the engine, and I can not get it there. Does anyone have any top tips? I have tried turing the engine over whilest I wiggle the gear box forwards and all sorts but I am propper stuck. I have removed the starter motor.
Cheers,
Jack
wackos00
PostPosted: Sun Jun 28, 2009 8:25 pm    Post subject: Reply with quote
It's cool, got it on, just had to take it off, re-align and try agian, so got it back on ok.... now though it wont start!! I'm not getting a battery light on the dash, and so not getting the fuel pump priming, or anything!!
