hansend23 Jedi Master
Joined: 04 Mar 2009 Posts: 333 Location: Washington state
Posted: Thu Mar 05, 2009 6:36 pm Post subject: you built oil sump |
this is my frist post,im wondering if anyboby is building there own oil sumps
for what ever engine you run.i built one for my 91 ej22. ive got the harness and adaptor ready.all i have now is cooling and exhaust.
is there a place for oil sump posts? ill keep checking.this is the website ive been looking for.i had many questions and they are now answered.its a nice place. _________________ just do it!
sven Jedi Guardian
Posted: Thu Mar 05, 2009 8:17 pm Post subject: |
| Yep, a couple different. I will mould a new one for my bus EJ20. |
Posted: Sat Mar 07, 2009 4:59 pm Post subject: |
are there any oil sump ideas on here?ive almost searched everything,thankx.Clay,who used to work with me,is doing his conversion here too now.he has a 66 bug and using a 91 ej22 also.and needs clearence from the road  _________________ just do it!
Posted: Thu Mar 26, 2009 6:38 pm Post subject: |
heres a not so good picture of mine.i copied the KEP design from
picts.ill add more out the other side later.
sven Jedi Guardian
MostlyMonki Jedi Master
Posted: Fri Mar 27, 2009 10:47 am Post subject: |
search for "oil sump", we dont tend to call them pans over here  _________________ '72 Ratty Bug - Subaru EJ20 Turbo motor. |
Posted: Sat Mar 28, 2009 5:47 am Post subject: |
made the appropriate changes  _________________ just do it! |
easy-does-it Jedi Guardian
Posted: Sun Apr 12, 2009 5:28 pm Post subject: |
I know it's my own fault for not checking before i started , but does anyone know the distance between the oil pump pick up pipe and the sump????..
Ive cut my sump down and cut the pick up pipe giving a ten mm clearance and just want to see if this will be ok... _________________ '76 bay going superfly TDI |
Posted: Mon Apr 13, 2009 3:31 pm Post subject: |
when i did my research i remember13mm.but ive seen closer.
and some weld a rod across the bottem so if it gets crushed,it will
still pick up oil.across the pickup screen. _________________ just do it! |
Posted: Mon Apr 13, 2009 7:50 pm Post subject: |
Cheers dude, i feel happier now  _________________ '76 bay going superfly TDI |
