joker Wannabe
Posted: Sat Mar 07, 2009 8:23 pm Post subject: Full kit for MK3 Golf 2.0 conversion? |
I've been toying with a change for ages - we want to go to Europe in the van this summer so i'm biting the bullet - its either change the 1.7 CB engine in the back for a recon, or stick a conversion in.
I've been offered a mk3 golf 2.0 ltr engine - is there a complete kit I can get to do a simple and quick conversion? I can sort out the cooling etc, i'm more concerned about engine mounting, gear box adaptors and any lubrication changes required. I'm mechanical enough to change an engine and gearbox for a straight swap but don't want to get half way through and find it too challenging.
The box in the van is the 1.7 CB unit which came with the engine
Advice appreciated.
Cheers |
Posted: Mon Mar 09, 2009 11:34 am Post subject: |
cb engineering used to do a kit - i think they are still going but no longer do it.
kennedy in the US do an adaptor.
or you can go with T25 deisel bellhousing - but this does tip the engine right over and you would need to sort the sump and pump pick up accordingly. |
beetleseb Jedi Knight
Posted: Tue Mar 31, 2009 11:41 am Post subject: |
I've used a kennedy adaptor and its really nice
Engine mounts etc are fairly easy, its quite a simple conversion
I can do the wiring for you for £100 too
Seb _________________ Everybody is someone else's weirdo |
