Alex (FTS) Jedi Guardian
Posted: Wed Mar 04, 2009 5:44 pm Post subject: Servo vacume pipe |
HI. Does it matter what type of pipe I use for the vacume pipe conecting the servo? Does it have to be that stiff polyurathane tube or could I use a stiffish rubber hose?
Alex _________________ www.faltownskateboards.com |
Posted: Wed Mar 04, 2009 7:54 pm Post subject: |
Ok my friend at the hose shop has given me some lovelly pipe to use for my servo but it is only rated upto 10 bar and I have noticed other specific servo vacume ube is rated at 15 bar. Do you think my 10bar hose will be OK?
Posted: Wed Mar 04, 2009 9:32 pm Post subject: |
Errm I could be wrong here but if it's measured in bar that's for +ve pressure, ie blowing down it
When I did my servo pipe it was bloody expensive & came from a main dealer. It has a steel spiral in it. It stops it collapsing from the vacuum.
*looks on net*
£18.50/m from Heritage
http://www.vwheritage.com/vwh/VW-Camper-Van-Parts%5CBus-Parts-1968-79%5CBrakes%5CBrake-Pipes-Servo%5C?templateID=vwh
Item 28 (well it is for mine) near the bottom _________________ The advice you receive on here is worth the paper it's written on.
paul_f Force Sensitive
Joined: 01 Mar 2009 Posts: 18 Location: Chatham, Kent
Posted: Wed Mar 04, 2009 11:18 pm Post subject: |
hello newbie  _________________ The advice you receive on here is worth the paper it's written on.
Posted: Thu Mar 05, 2009 12:00 pm Post subject: |
Hello there! I have finally stopped lurking!
If you wanted to make it cheaper you could use 15mm microbore tube. I orginally used this, but found it too hard to bend it neatly whilst under the bus! |
Posted: Thu Mar 05, 2009 1:09 pm Post subject: |
Nice one guys-I wont waste my time fitting the pipe I have as it sounds like it's not the right kinda stuff. Thanks for the heads ups guys!  _________________ www.faltownskateboards.com |
Posted: Fri Mar 06, 2009 9:50 am Post subject: |
| ive used car heater hose in the past with no problems. its about the correct diameter and well cheap. I will be using it again when the time comes (very soon hopefully) |
pugvan Initiate Jedi
Posted: Fri Mar 06, 2009 10:39 pm Post subject: pipe |
| how about coper pipe or plastick plumbing pipe with ruber pipe at the ends |
Posted: Sat Mar 07, 2009 6:15 pm Post subject: |
Got some more pipe on ebay in the end it was 15 squids inc p&p which wasnt too bad. Soooo today I plumbed in servo vacume pipe up and made some new brake lines up to link the new master cylinder in. Soooo happy days  _________________ www.faltownskateboards.com |
