Servo vacume pipe
PostPosted: Wed Mar 04, 2009 5:44 pm    Post subject: Servo vacume pipe Reply with quote
HI. Does it matter what type of pipe I use for the vacume pipe conecting the servo? Does it have to be that stiff polyurathane tube or could I use a stiffish rubber hose?
Alex
PostPosted: Wed Mar 04, 2009 7:54 pm    Post subject: Reply with quote
Ok my friend at the hose shop has given me some lovelly pipe to use for my servo but it is only rated upto 10 bar and I have noticed other specific servo vacume ube is rated at 15 bar. Do you think my 10bar hose will be OK?
Alex
PostPosted: Wed Mar 04, 2009 9:32 pm    Post subject: Reply with quote
Errm I could be wrong here but if it's measured in bar that's for +ve pressure, ie blowing down it
When I did my servo pipe it was bloody expensive & came from a main dealer. It has a steel spiral in it. It stops it collapsing from the vacuum.
*looks on net*
£18.50/m from Heritage
http://www.vwheritage.com/vwh/VW-Camper-Van-Parts%5CBus-Parts-1968-79%5CBrakes%5CBrake-Pipes-Servo%5C?templateID=vwh
Item 28 (well it is for mine) near the bottom
paul_f
PostPosted: Wed Mar 04, 2009 10:35 pm    Post subject: Reply with quote
Thinkauto are pretty cheap for brake servo hose. Most motor factors don't keep it on a reel anymore, only in lengths of 1m.
The pipe I have used for the length of my bus didn't have a metal wire in it, but some does
http://www.thinkauto.com/acatalog/On_line_shop_Vacuum_servo_hose_129.html
PostPosted: Wed Mar 04, 2009 11:18 pm    Post subject: Reply with quote
hello newbie Wink
paul_f
PostPosted: Thu Mar 05, 2009 12:00 pm    Post subject: Reply with quote
Hello there! I have finally stopped lurking!
If you wanted to make it cheaper you could use 15mm microbore tube. I orginally used this, but found it too hard to bend it neatly whilst under the bus!
PostPosted: Thu Mar 05, 2009 1:09 pm    Post subject: Reply with quote
Nice one guys-I wont waste my time fitting the pipe I have as it sounds like it's not the right kinda stuff. Thanks for the heads ups guys!
PostPosted: Fri Mar 06, 2009 9:50 am    Post subject: Reply with quote
ive used car heater hose in the past with no problems. its about the correct diameter and well cheap. I will be using it again when the time comes (very soon hopefully)
pugvan
PostPosted: Fri Mar 06, 2009 10:39 pm    Post subject: pipe Reply with quote
how about coper pipe or plastick plumbing pipe with ruber pipe at the ends
PostPosted: Sat Mar 07, 2009 6:15 pm    Post subject: Reply with quote
Got some more pipe on ebay in the end it was 15 squids inc p&p which wasnt too bad. Soooo today I plumbed in servo vacume pipe up and made some new brake lines up to link the new master cylinder in. Soooo happy days Grin
