i think on the peugeot it fits at the back of the engineat the top facing a groove in the reaf of the flywheel . some peugeots picked a pulse from the loom in the dash after a stabilizer.... go for ford diesel, far easier, a proper good diesel. good luck ..nobby
Posted: Thu Aug 03, 2006 9:02 am Post subject:
Dissin the Ford
I have to agree pug engines are tops I have a Pug 206 Hdi and a Golf GT TDi 150 as my daily runners at the mo and I have to say the pug engine is far far smoother and doesn't smoke like the golf engine... however the golf is immensly faster.
I was always under the impression the Ford Diesel Engine was something to do with Peugoet ! anyone confirm or deny this ? _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
Posted: Tue Aug 08, 2006 9:52 am Post subject:
I dont think the old ones like ours is any thing to do with Pugeot. But the new ford/pug/citroen diesels are all made by ford now I think.
The pug and Citroen diesels have always had a good reputation, I think the old ford diesels have the reputation of just being basic. So I guess ford needed to flip the switch a bit! _________________ www.faltownskateboards.com
Hi I'd agree about the differences between the Peugeot and VAG group engines.
Every VAG diesel I see on the road smokes like a trooper, becasue its old technology pushed to the edge, the new Peugeot/Ford engines are far smoother and nicer engines
My friend has a 2.0lt HDI Citroen its a sweet sweet runner.
Joined: 20 Oct 2008 Posts: 23 Location: Canvey Island, Essex, UK
Posted: Fri Jun 11, 2010 2:53 pm Post subject: Re: rev counter on a diesel.....
illzlee wrote:
might be a silly one this to those with more engineering knowhow (about 95% of you!)
any ideas where i put the sender to my rev counter on a 1.9td pug/citroen engine?
I've tried putting it on several sensors and have comup with bob-all. :smt016
jp wrote:
On my Escort TD it comes off the alternator ! apparently
:smt101
If your alternator has a W-terminal (Bosch alternator) or equivalent, then that is the one to use with an appropriate rev counter.
W-terminal creation on a VW Type 4 engine's Bosch alternator
Some rev counters (i.e. tachometers) are incompatible with some electronic ignition systems, of which I was was warned in relation to my Microdynamics Formula 1, FCD electronic ignition system, with integral smooth-cut, adjustable rev limiter, which I retro-fitted in 1989, to my 1973 VW "1600" Type 2.
Hence, it seemed prudent to use the type of rev counter, intended for diesel-engined cars, which derives its signal from the alternator, requiring the creation of a W-terminal, from which to sense one of the alternator's AC phases.
Note the blue-coloured solder joint, to which I connected a light-duty, insulated wire, with glass fibre, heat-resistant sleeving, which also connects to a home-made, ¼-inch blade terminal, set into the alternator carcass, using epoxy resin and small offcuts of blue-coloured, glass-fibre printed circuit-board material.
The two red-coloured solder joints, are alternative sites, to which I could have connected an insulated wire, to create a W-terminal facility. _________________ Nigel A. Skeet
Posted: Sat Jun 12, 2010 2:43 am Post subject:
Resurrection of an old un!
JP, I think this is maybeeeeee in the wrong forum
4 years old and no one noticed *coffee splurt over monitor icon required*
Happy daze
Dan, how did you sort it bud?
Thanks to Naskeet for his answer though _________________ The advice you receive on here is worth the paper it's written on.
According to the following book, the alternator terminal for tachometer (i.e. engine rev counter) connection, is labelled as either AC (Motorola), AC Tap (Prestolite), R (Silver Bullet), X (Niehoff) and W (Bosch, Ingram, Paris-Rhone & Valeo). No terminal labels were quoted in the book, for alternators branded as AC Delco, CAV, Lucas, Mitsubishi, Nippon Denso or SEV Marchal.
Alastair Garrod, "Electrics Afloat: A complete practical step by step guide for boat owners", Adlard Coles Nautical (in association with Practical Boat Owner magazine), 2002, ISBN 0-7135-6149-6. _________________ Nigel A. Skeet
Posted: Sat Jun 12, 2010 11:36 pm Post subject:
Thanks for the info Naskeet.
I wasn't taking the pee. If it came across that way, I apologise. Nice to have contributions fella. Much appreciated _________________ The advice you receive on here is worth the paper it's written on.
is naskeet's diagram above suitable for any VDO tachometer or is there a special one that will work off the "W" terminal on a diesel alternator. I have a fairly standard petrol-engine VDO tacho out of a Porsche 924 in my van and it was run off the petrol engine. Is it as simple as plugging in a wire from the W alt terminal to the signal input terminal on the rev counter?
