hydraulic clutch
jerry79
PostPosted: Fri Jul 18, 2008 8:51 pm    Post subject: hydraulic clutch Reply with quote
has anyone converted there van ( type 2) to hydraulic instead of cable?
79 twinslider bay 2.8 cologne v6
62 11window rhd split
02 passat tdi sport estate
86 1340mini
PostPosted: Fri Jul 18, 2008 10:42 pm    Post subject: Reply with quote
yes i have.
but I use a RJES bellhousing which means i didnt have to think much about that end as i used T25 stuff. At the pedal end though its very straight forward.
first you need to make a clevis mount on your pedal - ie weld a tab with a hole on it on. then make a push rod with clevis on to link to the above. then mount the master cylinder just behind the corner of the front removable belly pan. ill try and sort some pics when i have more time.
For pipes I used copper stuff (same size as gas pipe you use in campers)
jerry79
PostPosted: Sat Jul 19, 2008 6:39 am    Post subject: Reply with quote
will the type25 slave cylinder set up fit on my 091 type 2 gearbox?
86 1340mini
PostPosted: Sat Jul 19, 2008 6:54 am    Post subject: Reply with quote
im not 100% sure but i dont think it will as it uses a special bracket which bolts to the bellhousing. However you will probably be able to use a t25 bellhousing on your box. Like i said above though i havent done that end of things as my conversion bellhousing was already designed for it.
easy-does-it
PostPosted: Sun Nov 09, 2008 7:40 pm    Post subject: Reply with quote
Rich im a bit thick and dont quite understand what you mean about the clevis pin stuff.....
Any chance of those pics please Grin
'76 bay going superfly TDI
jerry79
PostPosted: Sun Nov 09, 2008 8:52 pm    Post subject: pics Reply with quote
yeah c'mon rich what about those pics?????
86 1340mini
PostPosted: Mon Nov 10, 2008 12:29 pm    Post subject: Reply with quote
some pics.....if you look carefully - the pedal has a tab welded to the bottom which the clevis from an old clutch cable attaches to. the clevis is welded to a rod which is the pushrod to actuate the master cylinder mounted behind. Also included a gratuitous picture of my shiny gearbox showing the RJEs bits.
easy-does-it
PostPosted: Mon Nov 10, 2008 6:05 pm    Post subject: Reply with quote
I see now, said the blind man......( took me a while Laugh Out Loud )
what's that master cylinder from dude???
......... had a quick look on ebay and nothing looks worthy.....
cheers
...........might have to change my user name to 'the apprentice'
easy-does-it
PostPosted: Mon Nov 10, 2008 6:24 pm    Post subject: Reply with quote
It's ok.....i found it!!......pretty obvious really
PostPosted: Mon Nov 10, 2008 10:03 pm    Post subject: Reply with quote
for everyone elses benefit its t25.....but you can use most other M/C - i used t25 because they are cheap available and also matched the slave cylinder i was using.
its an easy modification....i dont know why everyone with a RJES bellhousing doesnt do it. 1 less cable to snap.
jerry79
PostPosted: Tue Nov 11, 2008 7:02 pm    Post subject: Reply with quote
looks the bizz what type of clutch are you using and whats a "rjes" bellhousing?
86 1340mini
PostPosted: Wed Nov 12, 2008 12:34 am    Post subject: Reply with quote
Scooby --> VW gbox bell housing, throughly recommended Grin (No, we don't work for Rich)
Check out the second Ad over there on our home page ------> RJES.com
