familyvan Padawan
Posted: Fri Aug 08, 2008 10:07 pm Post subject: 205 PCD Rear Brake project |
Right i am currently IRS in the rear with Rear Bay Brakes.
I have been Pricing up a set of Rear disc and they come in at £800 ish.
Currently out of money.....
I am running 15" BRM
Where would i get blank rotor's big enough for a 205 pattern...
To start with....
What is the best calpier to use i have heard passat calipers are very good.
Thanks in advance.
Ste |
Posted: Sat Aug 09, 2008 12:38 am Post subject: |
what about a bay rear disk conversion with a set of 5x112 to 5x205 adaptors? a rear bay disk conversion can be done with new disks, calipers and modified rear hubs for about £300 _________________ 1964 rat 13 window deluxe 1Z tdi,
familyvan Padawan
Posted: Sun Aug 17, 2008 6:21 am Post subject: |
that sounds like a better idea completely.
What do i need and how is it done...
Will it increase the rear width.. I have a set of adaptors already...they are 10mm. |
vw nerd Force Sensitive
Posted: Fri Nov 07, 2008 7:32 pm Post subject: |
I can supply a bolt on rear disc brake kit will all parts needed for £600. This set up is with later bay 5x112 not 5x205. You will need adaptors if you want to run the early style wheel spacing. This rear disc brake kit can be seen on
http://www.ultimate-engineering.co.uk/ _________________ More T3 Parts For Sale
The need for speed continues.
Can't you make this thing go any faster!
Tim Shettle
Ultimate engineering
Bristol
Tel/txt 07810 320 464 |
