Posted: Wed Apr 23, 2008 9:32 pm Post subject: cheap oil cooler |
| hi thought i would share my find today at scrap yard looking for a cheap air to oil cooler to keep temp down on my 1.9td splity? vauhall frontera petrol!!!! oil sandwich plate unscreweds of oil pump leaving you with a oil sandwich plate which will fit most modern engines under oil filter, it even has a built in oil thermostat! it came with a set of swagged rubber hoses with nice angled fittings and a rather large alloy oil cooler even better £10 the lot! |
naskeet Force Sensitive
Joined: 20 Oct 2008 Posts: 23 Location: Canvey Island, Essex, UK
Posted: Thu Oct 23, 2008 1:53 pm Post subject: Re: cheap oil cooler |
| 13 window deluxe wrote: | | hi thought i would share my find today at scrap yard looking for a cheap air to oil cooler to keep temp down on my 1.9td splity? vauhall frontera petrol!!!! oil sandwich plate unscreweds of oil pump leaving you with a oil sandwich plate which will fit most modern engines under oil filter, it even has a built in oil thermostat! it came with a set of swagged rubber hoses with nice angled fittings and a rather large alloy oil cooler even better £10 the lot! |
I think the VW 1.9 turbo-diesel engine, has the same sized oil-filter mounting, as the VW Type 4 style air-cooled engine. _________________ Nigel A. Skeet |
marcF020 Wannabe
Posted: Fri Jul 19, 2019 7:55 pm Post subject: Re: cheap oil cooler |
| 13 window deluxe wrote: | | hi thought i would share my find today at scrap yard looking for a cheap air to oil cooler to keep temp down on my 1.9td splity? vauhall frontera petrol!!!! oil sandwich Devis demenagement plate unscreweds of oil pump leaving you with a oil sandwich plate which will fit most modern engines under oil filter, it even has a built in oil thermostat! it came with a set of swagged rubber hoses with nice angled fittings and a rather large alloy oil cooler even better �10 the lot! |
Hello!
This is a good article because there are many tips and also many advices that will be very useful to me. |
