205 PCD Rear Brake project
familyvan
PostPosted: Fri Aug 08, 2008 10:07 pm    Post subject: 205 PCD Rear Brake project Reply with quote
Right i am currently IRS in the rear with Rear Bay Brakes.
I have been Pricing up a set of Rear disc and they come in at £800 ish.
Currently out of money.....
I am running 15" BRM
Where would i get blank rotor's big enough for a 205 pattern...
To start with....
What is the best calpier to use i have heard passat calipers are very good.
Thanks in advance.
Ste
PostPosted: Sat Aug 09, 2008 12:38 am    Post subject: Reply with quote
what about a bay rear disk conversion with a set of 5x112 to 5x205 adaptors? a rear bay disk conversion can be done with new disks, calipers and modified rear hubs for about £300
familyvan
PostPosted: Sun Aug 17, 2008 6:21 am    Post subject: Reply with quote
that sounds like a better idea completely.
What do i need and how is it done...
Will it increase the rear width.. I have a set of adaptors already...they are 10mm.
vw nerd
PostPosted: Fri Nov 07, 2008 7:32 pm    Post subject: Reply with quote
I can supply a bolt on rear disc brake kit will all parts needed for £600. This set up is with later bay 5x112 not 5x205. You will need adaptors if you want to run the early style wheel spacing. This rear disc brake kit can be seen on
http://www.ultimate-engineering.co.uk/
More T3 Parts For Sale
The need for speed continues.
Can't you make this thing go any faster!
Tim Shettle
Ultimate engineering
Bristol
Tel/txt 07810 320 464
