kool idea
jerry79
PostPosted: Tue Jul 22, 2008 9:30 pm    Post subject: kool idea Reply with quote
ive been pondering with the idea of an aux electric water pump to assist with the flow as my kooling system has twice the capicty as the original engines pump was designed for, and i think it strugles to cope . has anyone done or heard any thing like this?????
79 twinslider bay 2.8 cologne v6
62 11window rhd split
02 passat tdi sport estate
86 1340mini
Covin
PostPosted: Tue Jul 22, 2008 10:11 pm    Post subject: Reply with quote
Yep, used very often on kitcars etc. Think there just over £100 for the pump. They do work very well
DARREN
I LOVE RUST ME
PostPosted: Wed Jul 23, 2008 8:28 am    Post subject: Reply with quote
i think cleverchap is running one.
The problem is though you need a pump rated for continuous running...and they arent cheap. Davies Craig are a well known brand - i think their kit is about £200!!!! still im sure theres an alternative.
I read in PPC mag that they were hoping to run a central heating pump using an inverter in one of their cars!!! not sure how they got on...
jerry79
PostPosted: Wed Jul 23, 2008 9:54 pm    Post subject: Reply with quote
thanks guys im up for a davies craig as mentioned £250 with all the gear
still id rather that than another engine rebuild will keep you posted.
86 1340mini
PostPosted: Wed Jul 23, 2008 10:01 pm    Post subject: Reply with quote
Have a looksee at Brads "weekend" thread too:
http://forums.aussieveedubbers.com/viewtopic.php?tid=70364
Search for Davies Craig pumps on there too, a few are running them
PostPosted: Thu Jul 24, 2008 7:53 am    Post subject: Reply with quote
theres one here for £160
http://www.pistonheads.com/sales/528062.htm
quite an old advert but might be worth a go and a cheeky offer Wink
Cleverchap
PostPosted: Fri Jul 25, 2008 1:00 pm    Post subject: Reply with quote
I have a Davis Craig one in my bus, great piece of kit and can run totally independantly of the stocker on the engine.
Not cheap in the UK so I got mine shipped from Oz (where they are made) by a mate who lives out there.
Easy to fit and operate but be sure to get the termostat bulb that triggers their operation or else you can only run them direct off ignition.
My comes on at just below standard engine temp so it allows the water to get up to operating temp quickly to reduce over cooling and engine wear. Wink
If you need any other help give me a shout
jerry79
PostPosted: Mon Jul 28, 2008 9:41 pm    Post subject: Reply with quote
good stuff, how much of the time does your buses electric fans run to keep the temp down with the davies craig pump fitted. is there a noticable before and after difference.
the thing is you see my fans seem to be running about 50 percent of the time and im trying to reduce this.
86 1340mini
PostPosted: Mon Jul 28, 2008 9:53 pm    Post subject: Reply with quote
sounds like you need more airflow
jerry79
PostPosted: Tue Jul 29, 2008 7:14 pm    Post subject: Reply with quote
yes indeed mr 13 window, however after looking through the radiator archive for busses there is nothing there ive not already tried, apart from all the look at my radiator pot rivited to the front panal or engime lid ideas. (yuk)
my idea is to have a working cooling system that does not mean altering the bodywork or apperance of the van.
dont get me wrong my bus will do 80/85 mph for a couple of hours with out going over 90 degrees but the kenlows are working quite a bit and its this that im trying to reduce
.any good ideas please.
86 1340mini
PostPosted: Tue Jul 29, 2008 9:20 pm    Post subject: Reply with quote
Can you post some photos of your set-up?
Mine bus didn't have a prob cruising at 80mph, 3 full grown adults onboard on sat/sun in Kent/Sussex. The engine temp stabilised within the 'stat range ie 78-82°.
PostPosted: Tue Jul 29, 2008 10:32 pm    Post subject: Reply with quote
that sound good!
