bay window gear ratios
trev
PostPosted: Sun Jun 01, 2008 4:14 pm    Post subject: bay window gear ratios Reply with quote
Rich, you were looking for bay window bus gear ratios, hope this helps:
http://thekombikonnection.myfreeforum.org/Manual_transmissions_about217.html
1600 ------- 1700-------- 1800---------- 2000
---1st 3.80:1---------3.80:1-------3.80:1--------3.78:1
---2nd. 2.06:1---------2.06:1--------2.06:1-------2.06:1
---3rd 1.26:1---------1.26:1--------1.26:1-------1.26:1
---4th 0.82:1---------0.82:1--------0.89:1--------0.88:1
--- Reverse 3.62:1---------3.80:1--------3.80:1--------3.79:1
----Final drive 5.375:1 --------5.375:1-------4.851:1-------4.57:1
http://thekombikonnection.myfreeforum.org/Gearbox_ratios_about291.html
http://thekombikonnection.myfreeforum.org/forum19.php
PostPosted: Sun Jun 01, 2008 5:38 pm    Post subject: Reply with quote
Cheers Trev, they've filled in a couple more gaps in the table
pepper
PostPosted: Thu Jun 05, 2008 8:05 pm    Post subject: Reply with quote
I once found an ace conversion website over in Australia, chap had a V8 powered bus (which may jog someones memory),
Basically you could put all your gear ratios, diff ratios and tyres with aspect ratios in and it would work out all your speeds in each gear!
It was a flimpin ace little bit of software and I've never been able to find it again since (my computer Hard drive collapsed!
I used it to work out what speeds my bus would theoritically manage before I converted it to diesel.
pepper
PostPosted: Thu Jun 05, 2008 8:10 pm    Post subject: OH yes Reply with quote
Here u go, I nipped over to Google OZ and had a search there!
http://www.geocities.com/motorcity/garage/1811/
call_giles_
PostPosted: Thu Jun 12, 2008 9:33 pm    Post subject: Reply with quote
blimey, thought it worked out to going to fast! then realised its it kmh!
pepper
PostPosted: Tue Jul 01, 2008 9:30 pm    Post subject: Reply with quote
LOL at Giles, I did similar when I first looked at it.
