Air Filter for 2.2 non turbo in T25
wackos00
PostPosted: Fri Jun 06, 2008 1:44 pm    Post subject: Air Filter for 2.2 non turbo in T25 Reply with quote
Hi can anyone point me in the right direction, I currently have my 2.2 legacy engine in the back of my T25. The main problem is that where the current air filter hose is located it is touching the sides of the engine bay, and once i put a filter on, the filter will be pushed up against it. Does anyone have a solution to my problem, and what filter can I simply put on?
Cheers,
Jack
bartw_portland
PostPosted: Tue Jun 10, 2008 7:37 pm    Post subject: Reply with quote
Jack:
I've used several filter arrangements on vanagon (T25) conversions including the stock subaru air filter box, a KEP air filter enclosure, and an aftermarket (K&N) cone style air filter.
The cone style are the noisiest but also tend to be the easiest fit because they are much smaller than KEP or Subaru's offering.
As to modifying the air intake plumbing to clear your firewall....I've heard of folks heating the black plastic slowly to reform the tube in such a way as to avoid the firewall (engine bay wall). Have also seen engine bay walls cut to avoid the tubing although that's a bit drastic.
All the best,
Brent
Brent Weide
Portland, Oregon, USA
www.weidefamily.net/vanagon/
PostPosted: Tue Jun 10, 2008 7:48 pm    Post subject: Reply with quote
Hey Brent
Great to have you on board. Your site has helped loads of people out.
wackos00
PostPosted: Wed Jun 11, 2008 8:39 am    Post subject: Reply with quote
ok so one of these then click just need to find what is the right id i need for the filter, do they simply push on then a jubilly clip in place?
